All-in-one type of device
Nadzin
Hi everyone,
I'm looking for a compact all-in-one unit for desktop use. I'd prefer something small to medium-sized rather than a large component.
My requirements are:
  • Amplifier for passive speakers (it doesn't need to be very powerful, as it will be driving a pair of Buchardt P300 speakers in a small room);
  • Good headphone amplifier that doesn't produce any audible hiss with sensitive IEMs;
  • A high-quality DAC;
  • Bluetooth would be a nice bonus, but it's not essential.
I'm not sure if there's a single device that checks all these boxes, so I thought I'd ask for your recommendations. Any suggestions would be greatly appreciated!
Hi everyone,
ASR has measured the Topping MX3 but not the 'MX3s'
I don't know if the headphone jack will produce audible hiss with a sensitive IEM.
One could try out the MX3s if you have access to a vendor with a return window like Amazon USA
So just a decent integrated amp without particular input requirements? What about bass management/eq? Why worry about "high quality dac" when using BT?
I don't need EQ or bass management.
As for Bluetooth, it would just be a nice extra. I don't expect to use it very often—only occasionally.
One feature I forgot to mention in my original post is that I'd like to be able to switch easily between my speakers and my headphones without having to unplug or turn off either of them.
4k€ its off my budget but its looks good, my budget its between 600 - 800e
Then Wiim etc and not worry about Hypex etc.
If you can tolerate two boxes, a Topping DX5II and a Fosi amp fit the bill well within your budget.
I can't think of an easy win that has headphone and poweramp in one box, though.
This is what I have right now: three boxes—one DAC/amp combo for my headphones and IEMs, plus a separate DAC and amp for my speakers. I'd like to simplify everything down to a single box. I've also thought about switching to active speakers, but that's not really an option for me at the moment.
Hi everyone,
Cannot vouch for it as I don't own it, but the following strikes me as an unit covering most of what you ask for apart from headphones which would be solvable by a separate unit to your liking (Toslink)....
Believe there are tests of similar hardware configurations but not this particular one which is fairly new. Looks like bluetooth is limited to 5.0 and there are notable improvements to more recent versions. Anyway, I keep this one in the back of my mind as a potential starter with Ascilab F6B / F6Bs and it would do just fine for that by the looks of it. I think.
PS Audio Sprout100
Teac AI-303 (or any other of their small form integrateds that are out of production)
There's also the SMSL AO300 but aside from that and the Topping MX3s unit I don't know of many / any.
FWIW I have everything you're asking for save the power amp in a DX5 Lite... and use powered monitors. No complaints.
Ime everything you ask for but for a headphone out is in one box: the wiim amp. Or everything you ask for but not a power amp: a dac/pre/headphone amplifier.
That's why I would recommend a two box solution in desktop size. If you mainly use headphones:
I just switched from a Topping dx7 I used for headphones and as a preamp for active speakers. I can really recommend it. Loved it. Very easy to set up and use.
A turning amplifier knob proved valuable btw. From experience I would recommend to find a dac that has eq possibilities. Far cheaper options nowadays from topping are just as good.
I would look for a matching desktop power amp from topping. For example topping mini 300.
So many suggestions for a multi-box solution and so few suggestions that actually suit what the OP asked for. Better to let them decide if the single-box solution works than to convince them they don't need what they are asking for. That sort of thing that gives this forum a bad rap.
"Good headphone amplifier that doesn't produce any audible hiss with sensitive IEMs"
"A high-quality DAC"
"'m not sure if there's a single device that checks all these boxes, so I thought I'd ask for your recommendations. Any suggestions would be greatly appreciated!"
"my budget its between 600 - 800e"
Better let Nazin decide.
Hi everyone,
The $699 Denon CEOL RCD-N12 measures about 11 inches wide by 12 inches deep.
Amir measured a compact Denon PMA-50 amp in 2019.
A refurbished RCD-N12 is available for $499:
The $260 SMSL 'AL200' amplifier measures about 8 inches square:
Loxjie A40 or the SMSL version with the same features.
This SMSL: AO300-Pro.
