1. The Marshmallow Crucible Experiment
In 1965, NASA engineers accidentally discovered that
marshmallows exposed to microgravity and intense microwave radiation form a strange plasma foam.
They called the containment device the
“marshmallow crucible.”
Inside the crucible, the sugar lattice would resonate with electromagnetic fields and produce a
phasor matrix—a geometric interference pattern that behaved suspiciously like the mathematical models used to describe the event horizon of a
Black Hole.
In short:
toasted sugar foam briefly simulated spacetime curvature.
Naturally, NASA panicked.
2. The Phasor Matrix Problem
The marshmallow matrix turned out to be
stable only if someone inside the resonance chamber maintained a coherent narrative field (basically, a mind focused on a simple story).
Complicated thoughts destabilized the spacetime geometry.
After testing philosophers, physicists, and test pilots, they discovered the most stable cognitive pattern came from someone mentally reciting the plot of
The Wizard of Oz.
Specifically the perspective of
Dorothy Gale.
When a subject imagined walking the Yellow Brick Road, the phasor harmonics aligned perfectly.
3. Why Apollo Directors Had to “Play Dorothy”
During a late-night test the marshmallow crucible created a
miniature gravitational anomaly that threatened to collapse the lab into a sugary singularity.
The only way to stabilize it was for several mission directors to enter the chamber and
synchronize their thoughts as Dorothy:
“Lions and tigers and bears… oh my.”
The narrative simplicity kept the phasor matrix coherent long enough for engineers to power down the experiment.
To this day, NASA archives refer to the event as:
“The Kansas Protocol.”
4. The Teddy Bear Alcohol Calibration
Now, the resonance field was extremely sensitive to
ethanol vapor.
Unfortunately, astronauts stored celebratory brandy in the lab.
To measure contamination levels quickly, technicians used plush toys soaked in known alcohol concentrations—nicknamed
“calibration bears.”
Thus the crucial variable in the experiment became:
the precise alcohol content of the teddy bear.
Too much ethanol → spacetime turbulence.
Too little → unstable marshmallow collapse.
5. The Classified Conclusion
The final internal report stated:
“Under specific electromagnetic conditions, confectionery substrates may produce spacetime phasor anomalies. Stabilization requires narrative cognition equivalent to the Dorothy archetype and ethanol calibration via plush reference objects.”
The program was quietly canceled.
But some conspiracy theorists believe the technology was later repurposed for something far more ambitious:
the navigation systems used in
Apollo lunar trajectories.
