It’s pretty common knowledge on the forum that DAC’s and amps are transparent. Unless they’re flawed or broken.Well the K9 pro retreived more detail in my listening tests than my DX5 so probably...yes.
Double blind and volume matched? If not, then you've introduced enough bias that your anecdotal report is fairly pointless.There are OBVIOUS and CLEAR differences between the K9 pro and Topping DX5. I even named the track and the detail...if anyone has these two dac/amps feel free to do the comparison. I fully stand by my comment.
I literally A>B them over and over and the song is so familiar to me having listened to it thousands of times.
I listen loud but not technically volume matched. But its not required because the musical passage i'm talking about is barely audiable on the topping and is so obviously clear and detailed on the K9. Its clear as day...i invite anyone with the means to test the same track on the same two devices and come to a different conclusion. It was also consistent across headphones(hd650, hd600, k702, sundara, etc). Put it this way i could listen at a lower volume on the K9 and hear the effect clearer than on the topping at a louder volume...it's that obvious.Double blind and volume matched? If not, then you've introduced enough bias that your anecdotal report is fairly pointless.
So the level is higher K9. It explains what you heard.I listen loud but not technically volume matched. But its not required because the musical passage i'm talking about is barely audiable on the topping and is so obviously clear and detailed on the K9. Its clear as day...i invite anyone with the means to test the same track on the same two devices and come to a different conclusion. It was also consistent across headphones(hd650, hd600, k702, sundara, etc).
I could point out other smaller differences(voices in the crowd on the same track etc) but this one was so major and clear it's enough alone imo.
Nope. I didn't say that. What i said was the difference in the musical passage was clear even if the DX5 was set clearly louder than the K9.So the level is higher K9. It explains what you heard.
And with that reasoning all your observations are pointless and worthless.I listen loud but not technically volume matched. But its not required because the musical passage i'm talking about is barely audiable on the topping and is so obviously clear and detailed on the K9. Its clear as day...i invite anyone with the means to test the same track on the same two devices and come to a different conclusion. It was also consistent across headphones(hd650, hd600, k702, sundara, etc). Put it this way i could listen at a lower volume on the K9 and hear the effect clearer than on the topping at a louder volume...it's that obvious.
I could point out other much smaller differences(voices in the crowd on the same track etc) but this one was so major and clear it's enough by itself.
The objectively best performing devices all use single DAC chip design, use a "simple" switching power supply and don't have THX amp topology.How so?
But you are saying the level is higher. Unless the devices are level matched and you do a double blind test your opinion is flawed and discounted as subjective.Nope. I didn't say that. What i said was the difference in the musical passage was clear even if the DX5 was set clearly louder than the K9.
Again, I literally didn't say that. I said its very noticeable at what i consider similar volume, BUT even if i run the K9 at a much lower volume than the topping, the difference in the segment stands out like a sore thumb. Its so obvious you'd have to have either seriously bad ears, or be utterly brainwashed not to hear the difference. Anyway unless someone can match the kit like i did and listen to the track in question then you can't say i thing. I've A>B and even clearly hear the difference when the topping has the advantage of a louder volume.But you are saying the level is higher. Unless the devices are level matched and you do a double blind test your opinion is flawed and discounted as subjective.
Ahh yes "without question". I guess we better stop questioning you, then!got jumped on for pointing out a sonic difference which exists without question. LOL.
I have owned both units at the same time...pointed out the exact difference at the exact moment it happens. Happy to have someone else A>B and come up with a different conclusion...highly doubt it will happen mind.Ahh yes "without question". I guess we better stop questioning you, then!
But that is the problem. You didn't level test it so the K9 is at a higher level. There really can't be any difference between the 2 devices went set up correctly for a test. There is a very long thread here for you.at what i consider similar volume
You are willfully ignoring the part where i have said multiple times the difference was crystal clear even when the topping was VERY much louder. You just dont want to hear it.But that is the problem. You didn't level test it so the K9 is at a higher level. There really can't be any difference between the 2 devices went set up correctly for a test. There is a very long thread here for you.
Message to golden-eared audiophiles posting at ASR for the first time...
Hello friend. Hey, listen...we know how it is. Believe me, most of us have been there too. You've spent years toiling in the muck of audiophilia. You read ALL the reviews. You watched ALL the youtube videos. You visited ALL the other forums where everything always makes a difference. You...www.audiosciencereview.com
The fault indicator on the K9 is either a solid or flashing red ring around the voume wheel. Try a different kettle plug perhaps if the fuse is DOA?Hey my K9 Pro ESS arrived in Thailand today but it doesn't turn on. I'm using correct voltage.
Simply no lights. Is this a common problem? Anything I can do to troubleshoot besides waste hundreds more on import costs by returning it?
Already tried holding "input" for 10 secconds.
I've heard you, but science is not on your side so I discount your claim.You are willfully ignoring the part where i have said multiple times the difference was crystal clear even when the topping was VERY much louder. You just dont want to hear it.
If one device is clearly and obviously set louder and still cannot deliver the detail in a segment that the quieter device is delivering...then what do you call that?I've heard you, but science is not on your side so I discount your claim.
Scientific rigor isn't confirmation bias.If one device is clearly and obviously set louder and still cannot deliver the detail in a segment that the quieter device is delivering...then what do you call that?
I call your own argument willful ignorance so far based off you ignoring my repeated statements that don't suit your own confirmation bias.
You can stamp your feet and yell from the top of the tallest building "I CAN HEAR A DIFFERENCE". I simply don't believe you can.If one device is clearly and obviously set louder and still cannot deliver the detail in a segment that the quieter device is delivering...then what do you call that?
