AliExpress cheap low distortion analog sine generator - review and measurements
I bought this generator from AliExpress at $16.50 (shipment and VAT included). The product page is below:
1. Info from aliexpress page:
Feature:
1. 1KHz sine wave output with a distortion coefficient of only 0.000064%, suitable for high-precision testing applications.
2. Ultra low distortion design, with distortion less than 0.001%, ensuring signal purity and stability.
3. The power supply is ± 15V, with a current of only 30mA, making low-power operation more efficient and energy-saving.
4. Output voltage greater than 7V, suitable for harmonic distortion testing, level testing, and regenerative power supply scenarios.
5. Adopting the NE5532 chip, it has good performance and effective use.
Product parameters:
Power supply: ± 15V, 30mA
Output voltage: greater than 7V
Distortion: less than 0.001%
Dimensions: 90 * 49mm * 16mm
Product Description:
Low distortion coefficient sine wave oscillator circuit board, oscillation frequency: 1 KHz, ultra-low distortion, distortion coefficient 0.000064% (-124dB). Can be used for harmonic distortion testing, level testing, regenerative power supply, etc.
The capacitors that control the oscillation frequency on the board are selected and paired using a digital meter. The resistor that controls the oscillation frequency is a 3.3K resistor and a 200 ohm 3296 multi turn potentiometer connected in series. The pairing is adjusted by measuring with a digital meter to ensure the accuracy and low distortion of the output frequency.
matters needing attention:
In theory, R10=2R13, C3=2C4, Minimal distortion.
2. The data in the figure is a value of 1KHZ. If there are other frequencies, besides R6, R7, C1, and C2 that need to be adjusted accordingly, R11 should also be modified according to the frequency.
For example: 50HZ, R11=447K, 60HZ, R11=408K.
Product List:
1X module
2. My additional description
The generator arrives as an assembled printed circuit board with through hole parts. It needs 2x15V (+/-15V) power supply, which is not a part of delivery. After connecting to power supply, it starts to run and gives 7Vrms approx. output voltage at single-ended output terminals. If the output voltage is too high, it may be reduced by external resistor voltage divider. The web page shows circuit schematics, you may see it in the attached pdf file.
3. Measurements
I connected the generator to a 2x15V external power supply and measured the output with E1DA Cosmos ADC at 10V input setting. Without further adjustments, output frequency was 934 Hz, output voltage 6.983Vrms, THD = 0.00011% and THD+N = 0.00022%. SNR = 114dB. These are excellent results for analog generator and especially at such price.
4. Conclusion
For those who need a cheap and clean sine generator, this is an excellent choice. Most of the soundcards are unable to generate such clean signal.
Edit September 04 - I have placed the generator board into a shielded box and the 50Hz mains line has c0mpletely disappeared:
Feature:
Product parameters:
Product List:
1X module
3. Measurements
4. Conclusion
