Just looked at SMSL RAW DAC1 vs RAW MQD1 (and Topping dx5 ii). Looks like the only difference that would matter to me at the moment is the AK4499ex vs ES9039Q2M chiset. Are there differences/benefits/tradeoffs at this point?
Why would that difference matter to you?Just looked at SMSL RAW DAC1 vs RAW MQD1 (and Topping dx5 ii). Looks like the only difference that would matter to me at the moment is the AK4499ex vs ES9039Q2M chiset. Are there differences/benefits/tradeoffs at this point?
These are well-engineered DACs and AFAIK most of the tradeoffs have been dealt with to the point that they will not be audible (even a little) in use. So if that is the only sticking point for you, I guess buy the one that's cheaper or that you think looks cooler.Are there differences/benefits/tradeoffs at this point?
AKM , the M stands for mmmmmmMusicalDifference is ESS picked a company name that sounds sibilant, and a product line “sabre” that sounds sharp. So people think that’s how they sound. Otherwise there is no difference.
I find that the snare (left hand beat) is a bit more crisp with sharper transients when using a Yellow Circle instead of the Green Circle.Audiophile Knee Music...
JSmith
AKM — “Actually Keeps Music”
One has a built-in headphone amp the other does not.SMSL RAW DAC1 vs RAW MQD1
Uh huh...I found It analytical, a bit harsh at times and unmusical
The SMSL D300 does not have an ESS Sabre IC, but Rohm's flagship DAC chip BD34301EKV.I owned an SMSL D300 which I bought in mid 2023. That DAC uses the then top of the line Sabre IC. It Signal to noise ratio and dinamic range was superb. It has a very detailed sound, but after some time I found It analytical, a bit harsh at times and unmusical. For my taste Sabre IC's give measure great with test equipment, but how It sound is a different Matter. IS not the first Sabre based DAC I owned and they were not my cup of tea.
I then moved to the AK4191+AK4499EX SMSL DO300 EX. It sounded great despite being an inexpensive DAC with a built in headphones output.
Then, I saw SMSL's D400 PRO that also uses the AK4191+AK4499EX combo, on line, read some reviews and as I could return the D300 EX, I went for the D400 PRO. And I couldn't be happier with It.
Sound is very detailed, different from the detailed sound of a Sabre IC, with a fat bass, excellent imaging (and my speakers are KEF's Q550, the cheapest floor standing speakers on their catalogue) and with well recorded and mastered recordings, from CD to SACD, to High Rez PCM, It never sounds agressive, bright or harsh, but very musical and pleasing to the ears.
An IC D/A Converter can sound different depending on how its implemented on the DAC, the quality of the surrounding components, like power supply or the quality of the opamps used and of course, the electronic design of the DAC.
But in general I've only read good reviews from DAC's and other components that use the AKM AK4191+AK4499EX combo.
But as everything, it's a matter of taste, and I can't say that Sabre IC's are bad and AKM's are better than Sabre ones.
If you need a new DAC, my advice IS to get It from Amazon or another shop that can left you taste the DAC in your system, and if you don't like It, return It and try a different one.
Just my 0.02 $.
Then It must have mistaken It for the DO300. But I recall that back in 2023 It had the then top of the line Sabre IC.The SMSL D300 does not have an ESS Sabre IC, but Rohm's flagship DAC chip BD34301EKV.
Just my 0.02 $.
