AKM new flagship AK4191 + AK4499EX
KoiHime
MacCali
:facepalm:sad face for me - I just purchased E70 L70 stack a week ago... for sure, I can't tell the difference between these two dac chip, but I'm curious about how "Valvet" it sounds.
I mentioned for me the AKM dac is my favorite. I’ve heard them all. Implementation is key so you can’t truly says.
But to break it down in my perspective it’s like this:
Burr Brown/TI warm/dark spectrum absolutely not edgy/digital/sib
AKM same but toned down warmth and much more details are present vs BB. Sound gets sharper basically
CS chip is neutral with more detail present going towards ESS’s sharpest sound. I think I need to hear more CS chips, to give a conclusive result
ESS is basically ultra detail oriented and what some may consider as bright. Super clear and transparent. Also probably the least musical/warm/dark of the dacs.
I’ve been interested in the x26 pro but it’s pretty pricey and I love my D70s which has two 4497’s. Also the Monolith AC Liquid Platinum which uses the 4499
I’ve had 3 ess dacs and I did not like two of them absolutely. Too crisp for me, my Volumio primo has one and it sounds quite pleasant honestly. I stream direct from its internal dac quite a bit
KoiHime
I very much appreciate the detailed information!
MadMaxx
Islamorada, FL Keys
I liked my D400EX a lot, but the left channel stopped working suddenly. It's being returned to Apos Audio for refund. SMSL's QC reputation isn't the best, so I'm bit leery about buying another one. The Gustard A26 looks great, but I ain't about to drop $1500 for it. This new Topping definitely has my interest. No idea if there's a major sound difference between dacs with a single 4499EX compared to dual 4499EX. I'll order an E70 from Apos once my refund is issued.
Veri
My last 2 DACs were ESS Q2M series based so not even the expensive 'Pro' chips and I really don't hear the least 'musical/warm' thing you say... I remain sceptical. My CS(Cirrus Logic) basic macbook and meizu dongle don't really sound different from it either. Just 'good'. Lol.
My Audial TDA1541 DAC sounds darker/rolled off but that's because it has very little filtering as a design choice. It's based on an old 16-bit converter. Any proper designed DAC should not sound drastically different from another. I would say 'IMO' but it's hardly an opinion, it's also what the science around D/A conversion would dictate.. :p
Veri
Found it thanks! https://shenzhenaudio.com/collectio...-support-dsd512-pcm768khz-decoding-e70-velvet
Makes the E70V-A70 stack pretty tempting for people in the market right now, I guess :D
Looks like @WolfX-700 already measured it too!
MacCali
I feel you, your audio chain may have influence on it. Just equally as my results. I do not feel it's drastic, I just hear a difference.
I've had the 4490, 93, 93eq, 97, and 99og. Prior to these guys my favorite dac was a BB which I had 3 of prior to hearing AKM.
I know we are in a consistent notion that dacs do not have a sound, but I personally do not see that. I know I am applying all these words, but it's basically musical or analytical and it depends how far on the spectrum a product is. That's why I wanted to state this is in my opinion, nothing that is pure fact.
But at the same time, while mentioning the chain, you cant have everything on the dark side/musical and expect it to sound good. That's when you create mudy bass and super dull sound. In my chain the D70s + my parasound amps which are biased into class A + neutral speakers sounded good. However not as good as when I dropped the Pre90 into the chain which is a much more analytical sounding unit. Which to me was a balance into the whole thing
Also, when I first got my pre90 using the very same equipment mentioned man that thing was so bright. It took about 72 hours of burn in to kill that sound, it sounded extremely sharp to me and aggressively forward.
I know burn in itself is a controversial topic, but I definitely experienced it with that unit especially.
BR52
Germany
Now we have 2 implementations of the new AKM chipset and see a Hump. So, no technical competition to Ess anymore?
Veri
Maybe it's only so apparent because the noise floor is so low...?
BR52
Germany
Sure, a low noise floor makes it more visible, but the situation with a similar floor seems to be more or less solved in some ESS implementations. The I/V section is still not easy to design.
tuga
Oxford, England
There is no music even close to anything like this as far as I'm aware, so what's the point?
Almost all CD players and DACs up- or over-sample, often to the maximum admissible rate. Benchmark is an exception, (currently) choosing to up- or down-convert everything to 211kHz
You are missing the point.
MacCali
I do not see a hump on the Gustard unit. Honestly though, not sure if this is factorable, but at this level of performance with sinad is that even a factor? isn't the hump a product of distortion or noise, not sure which, but clearly none of it should be audible or maybe it is.
https://www.ap.com/technical-library/imd/ still could not get a precise understanding from this
Not getting much information for SMPTE either o.o
BR52
Germany
post#30
"Also, when I first got my pre90 using the very same equipment mentioned, man that thing was so bright. It took about 72 hours of burn in to kill that sound, it sounded extremely sharp to me and aggressively forward."
I would recommend you spend 72 hours to "burn in" (learn) about IMD. Google and search here in the forum can be really helpfull.:)
Veri
Burn in intermodulation distortion..? o_O
Mnyb
Sweden, Västerås
I don’t think we should spread fud/myths about different chips sounding remarkably different . Implementation is everything if the chips are of recent vintage not some relic of the 80’s or 90’s ?
Well built modern DAC’s exceeded our human capabilities long ago . Possibly exception is if you are young enough for excellent hf hearing then the weirdest filter choices with roll off on the top and ultrasonic leakage migth sound different to you .
Please don’t attribute texture detail or soundstage to a DAC , if such words cary any meaningful information it’s about the recordings
