AKG K712 Pro Open-Back Reference Studio Headphones $250 -Sold
Angstrom
The K712 PROs are reference, open, over-ear headphones for precise listening, mixing and mastering. Also great for gamming to the wide staging.
You can find them on Reverb for $250 dollars https://reverb.com/item/31452614-akg-k712-pro-open-back-reference-studio-headphones
The over-ear design guarantees maximum wearing comfort for fatigue-free mixing and mastering, while providing spacious and airy sound without any compromise. Their precise powerful sound results from improved low-end performance by 3dB.
These headphones have a genuine soft leather headband for a lightweight and comfortable fit. Their carefully selected transducers provide consistency and accurate localization.
The K712 PROs come with a professional mini XLR connector for quick replacement of the cable. Includes is a coiled cable.
Specs
  • Maximum input power 200 mW
  • Audio frequency bandwidth 10 - 39800 Hz
  • Sensitivity headphones 105 dB SPL/V
  • Rated Impedance 62 Ohms
  • Detachable cable yes
  • Cable Length 3 m
  • Earpads replaceable yes
  • TypeStereo plug – 3.5mm (1/8-inch) with 6.3 mm (1/4”) screw-on adapter
  • Physical. Weight. 8.3 oz / 235 g
