AKG K60 Vintage Headphone Review
Rate this headphone:
    Votes: 128 92.8%
    Votes: 5 3.6%
    Votes: 1 0.7%
    Votes: 4 2.9%
This is a review, listening tests and detailed measurements of the AKG K60, circa 1970s, new old stock headphone review. It is on kind loan from a member and costs US $170.
I am stunned how fresh, new and clean this headphone is! It feels like you have gone back in time. Owner sent this to me as AKG Vienna was supposed to have built this based on research:
Sounds kind of like how Harman researched headphone preference. Let's see where they got.
AKG K60 Headphone Measurements
They say a picture is worth a 1000 words:
I guess their research told them the main thing we care about is 100 to 500 Hz which considering that is vocal range, maybe that makes sense.
I am ignoring the bass distortion as that is high due to lack of output:
Take caution in looking at absolute distortion levels when the response is not flat:
Group delay is bizarre:
Impedance is quite high:
Sensitivity is slightly better than average:
AKG K60 Listening Tests
Listening to my first track, produced the muffled, "closed in a box" sound that you would expect. Interestingly, it was not annoying. It was a clean midrange response.
We have come a long way as far as knowing what a good headphone could be. Clearly a lot of bad ideas were going around decades back, even with good intentions in research and design.
requires a new category above '1' poor in the poll.
One could call it '0' awful. :)
That said, most headphones of that era probably did not measure well compared to today's standards.
Here are some thoughts about the EQ.
Please report your findings, positive or negative!
Notes about the EQ design:
  • The average L/R is used to calculate the score.
  • The resolution is 12 points per octave interpolated from the raw data (provided by @amirm)
  • A Genetic Algorithm is used to optimize the EQ.
  • The EQ Score is designed to MAXIMIZE the Score WHILE fitting the Harman target curve (and other constrains) with a fixed complexity.
    This will avoid weird results if one only optimizes for the Score, start your journey here or there.
    There is a presentation by S. Olive here.
    It will probably flatten the Error regression doing so, the tonal balance should be therefore more neutral.
  • The EQs are starting point and may require tuning (certainly at LF and maybe at HF).
  • The range around and above 10kHz is usually not EQed unless smooth enough to do so.
  • I am using PEQ (PK) as from my experience the definition is more consistent across different DSP/platform implementations than shelves.
  • With some HP/amp combo, the boosts and preamp gain (loss of Dynamic range) need to be carefully considered to avoid issues with, amongst other things, too low a Max SPL or damaging your device. You have beed warned.
  • Not all units of the same product are made equal. The EQ is based on the measurements of a single unit. YMMV with regard to the very unit you are trying this EQ on.
  • I sometimes use variations of the Harman curve for some reasons. See rational here and here
  • NOTE: the score then calculated is not comparable to the scores derived from the default Harman target curve if not otherwise noted.
Vintage!
Not great L/R match.
I have generated one EQ, the APO config file is attached.
Score no EQ: -5.2
Score with EQ: 85.5
Code:
AKG K60 APO EQ Flat@HF 96000Hz
June072024-170645
Preamp: -10.00 dB
Filter 1: ON PK Fc 47.5 Hz Gain 7.46 dB Q 0.79
Filter 2: ON PK Fc 76.7 Hz Gain 11.42 dB Q 1.12
Filter 3: ON PK Fc 111.7 Hz Gain -15.76 dB Q 1.52
Filter 4: ON PK Fc 287.0 Hz Gain -12.13 dB Q 0.76
Filter 5: ON PK Fc 1142.5 Hz Gain 8.36 dB Q 1.34
Filter 6: ON PK Fc 4160.4 Hz Gain 5.73 dB Q 1.22
Filter 7: ON PK Fc 6192.6 Hz Gain -6.69 dB Q 5.00
Weren't the extremely heavy but popular Koss Pro 4AA 'phones from this period similar in mid to upper balance (maybe there was more low bass in this latter though)?
Yes, they were awful, weren’t they? Headcrushers, I used to call them! I’d like to see the brilliant original Sennheiser HD414 alongside the AKG as I’m pretty sure I got mine in about 1971.
Massdrop 99 Noir:
HD414 from the same time period. These were quite comfortable though. (target = horizontal line)
and a Roelofs from the same time period:
and a 2015 (€ 5.-) headphone below
Considering how there was not much in terms of measurement equipment available during the development of this headphone, they're actually surprisingly close.
(They're not close *at all*, but imagine having to come up with a speaker design for headphones without being able to use an ear simulator during development..)
