You are correct, they sound better too, even without EQ. The treble range is especially clear present and non-fatiguing.
oratory1990 has published AKG K361 and AKG K371 measurements.
I've taken a look over Oratory's measurements and they seem pretty strange to say the least, best measurements I've seen so far are RTINGS's onesThis is why I only trust Oratory1990 measurements.
Oratory is an audio engineer with access to state of the art measurement equipment (see bottom of the measurement sheet) and knowledge to use it properly. I haven’t seen anyone else on the Internet with that kind of equipment.Are the Oratory measurements reliable or not? From those graphs the 371 seems the one to get. The sub tones are lifted, yet would that not just add ambient weight instead of the typical bloat pushng into the mids? I was going to get the 361 and then I see these charts.
Consider the following:
Measuring headphones is NOT remotely as accurate as measuring electronics and even measuring speakers.
It can provide some clues, that's all.
Now comes the difficult question... which one to trust ?
He actually designs transducer systems for products that get sold under big brand names.Oratory is an audio engineer with access to state of the art measurement equipment (see bottom of the measurement sheet) and knowledge to use it properly. I haven’t seen anyone else on the Internet with that kind of equipment.
So all others are considerably flawed and those 2 are not ?
In any case when EQ is based on one rig it will be fairly similar on the other... but what about ones ears ?
Are they the same as those rigs and why aren't other test rigs accurate ?
If a set of measurements is done on a newer generation rig, a piece of hardware specifically prescribed by the main researcher in the field, then yeah. It stands to reason it should be trusted more.So all others are considerably flawed and those 2 are not ?
Something I have become increasingly paranoid about is unit to unit variation. I have two Oppo pm-3, the black pair and the white and blue pair, and my wife and I are convinced they have different FR and the white and blue sound nicer. This is actually something we can practically blind test. Could be pads or clamping.
I've found that the measurements can be good in cluing you in to where there's a peak or a dip and maybe it's relative magnitude, but if you go whole hog on canceling that peak or dip you'll likely end up with somewhat unnatural results.
