AIYIMA T20 Tube Pre-amplifier Review
Rate this preamplifier:
    Votes: 10 4.0%
    Votes: 40 16.0%
    Votes: 126 50.4%
    Votes: 74 29.6%
This is interesting and amazing, I watched quite a few YT review on this thing and they all seemed to say "don't expect tube amp sound if just swapping out the SS preamp...". Yet I just did exactly that and the bass gained 200 lbs instantly, and unlistenable. It seemed like I was back to the distant past as a kid listening to the 5 WPC Loewe Opta Console Stereo receiver. I have to double check to see if I did anything wrong, otherwise it is going back despite the Amazon prime big deal price I got it for.
Why on earth return it because it responded badly to you swapping something on it? The swap is the problem not the unit!
I simply substituted the solid state preamp I was using, with the hybrid tube T20 preamp, everything else remained the same. Prior to purchase, I read/watched quite a few reviews on forums and Youtube, based on what people said, I expected to hear some tube like sound signature presumably due to higher THD dominated low order H2, H3, H4, hopefully mostly H2 and H4 harmonics, albeit wouldn't be very much because the T20 is just a hybrid tube preamp, yet the bass sound signature changed much more than I expected, to the point even DL ART could not do too much to tame the seemingly much longer decay making the deep to mid bass sounded way too soft to my taste.
I was going to spend some time troubleshooting in case I accidentally changed something, but when listening at lower level, I realized it was making some almost constant ticking sound on the left channel, switched the tubes between left/right channels, ticking continues, in fact both channels was doing it just that it was much louder on one channel. If it was the annoying ticking noise, I would most likely keep it, but with that it is going back for sure. I could try a second unit, but if the second unit would do the same then I would have to make any trip to return it so not going to take that risk.
Ah, sounds like bad luck. I thought you were comparing component changes in the T20. I have had excellent use of my T20 since I got it. Neutral, not soft in the bass or anything like that.
Sounds like you have a faulty unit, both with respect to the noise and excessive. I switched from a passive preamp to the T20. The bass simply improved but not excessively or artificially.
Hmm... sounds like time to roll tubes... or op amps.
:cool:
Yes, it seems reasonable to me to get back to basics—focusing on users and their experiences, whether positive or not. So, here is mine: after spending the summer having fun swapping tubes and doing some attentive, low-volume outdoor listening, I’ve formed an opinion. I am fully aware that my views are subjective and based solely on my own experience, but ultimately, the PSVANE 12AX7-S vacuum tubes gave me the most listening pleasure. I used the XLR inputs and outputs with high-quality cables. I didn't venture into modifying the op-amps. I won't dwell here on the scathing comments regarding the connection to my amplifier found in this discussion thread—comments that in no way reflect the reality of what I actually hear myself: https://www.audiosciencereview.com/...e-amplifier-review.66604/page-30#post-2637864
"A word to the wise!" :cool:
A number of posters have asked what's the point of this product given you can get better measured performance from a solid state device. Point taken, but is there a better measuring solid state preamp with the features of the Aiyima at this price (around $200 USD)? I have found two Fosis but both have drawbacks.
Its probably the flux that is causing the issue. My Ampapa H1 which according to japanese forums uses the same electrical design as the Aiyima T20 had some serious treble boost the first time i listened to it. Like ear bleeding treble. Cleaned the copius amounts of flux off the pcb, ran another RMAA test and the insane treble went away.
Uhhhh
For a change, on the subjective side... :
Has anyone with a bit of experience, on a well-known system, been able to listen to it with demanding music, acoustic type, etc.?
(no answer for gain??? and output impedance ? someone from aiyama seems to be following this thread..... ;-) )
To answer your question re subjective listening experience: I've listened to the t20 extensively over the past month, primarily to classical music from sonatas to symphonies. I have a lot of experience with live concerts in addition to recorded music. The t20's ability to create a listenable facsimile of a musical instrument or performance has been transformative compared to the various types of passive preamps I've used previously.
I have a 12 volt 5 amp Douk Audio brick power supply. Would this be any better for the Aiyima T20 than its own supplied 12 volt 2 amp wall wart?
