- Joined
- Dec 12, 2019
- Messages
- 17,111
- Likes
- 38,992
hmm...I think once it's past the 50-hour burn-in mark, things can only get better.
I tried using both stereo and mono 3.5mm cables, and it doesn't work with either.You need to use a 3.5mm stereo cable.
With other amplifiers or DACs, I wouldn’t ask you this—but do you have any subjective impressions of how this amplifier sounds? Does it “sound” any different from transistor amplifiers with similar specs?I am going to recommend the AIYIMA T20 preamplifier. Kudos for the company showing that such a product can be done well, outclassing many solid state products!
Why is this not enough? And who cares?other than having two tubes sticking out of the case
Me too. Even if it's just placebo I enjoy the visual.I appreciate that with the 'T20', Aiyima offers the option of a tube-based preamp with this level of measured performance.
Maybe just buy a box of birthday candles, and stick them on top of the components.Two "plinker" tubes (e.g., tubes with low emission or grid leakage, but with functional heaters) with their heaters powered by a low voltage AC supply capable of providing suitable power could be added to any audio component to provide the aesthetic and the warm glow. No connections to any of the tube's functional elements - plate, cathode, or grid(s) - are required.
OK, these particular tubes are active, but use low voltages even for their plates. No lethal voltages in this well-known DIY hybrid headphone amp from clever and generous audio designer Pete Millett.
(full disclosure - I've built a couple of these over the years.)
... and, of course, holiday decor is also an option!
NOT my series-string holiday lighting!I've been tempted, though...
Referring back to your quote from the original review: "Kudos for the company showing that such a product can be done well, outclassing many solid state products!"With other amplifiers or DACs, I wouldn’t ask you this—but do you have any subjective impressions of how this amplifier sounds? Does it “sound” any different from transistor amplifiers with similar specs?
If it doesn’t sound any different, I don’t see the point, other than having two tubes sticking out of the case that glow in the dark.
No sound coming out of the T20. It worked perfectly. No sound now. Tubes are warm and lit. I have tried all the combinations. It s now in another system of mine. I m getting mad.With other amplifiers or DACs, I wouldn’t ask you this—but do you have any subjective impressions of how this amplifier sounds? Does it “sound” any different from transistor amplifiers with similar specs?
Stopped working for no particular reason !!! I m getting mad. Requested assistance at Ali Express. Tubes are lit. Display is on. No sound. Mistery. Could it be a power supply issue?Wow! ()
I doubt it could be a power supply issue if the Tubes are lit. And both channels are not working as opposed to one or other. ...Stopped working for no particular reason !!! I m getting mad. Requested assistance at Ali Express. Tubes are lit. Display is on. No sound. Mistery. Could it be a power supply issue?
the plastic does not cover the red-blue led ----yes I switched the inputs--red blue---but no sound coming out---thanks for your attentionI doubt it could be a power supply issue if the Tubes are lit. And both channels are not working as opposed to one or other. ...
Make sure that if you are using balanced you have not defaulted to RCA output or vice versa ...
I got caught out by that once! Your tape covering the display would also hide this ... blue I think is balanced, and red is RCA.
Finally l solved the problem, l even bought a new T20! Thinking the other one was broken. The problem was in the out put of the smsl dac 200 pro. Switch was in balanced. But no sound came out.the plastic does not cover the red-blue led ----yes I switched the inputs--red blue---but no sound coming out---thanks for your attention
No my DACs they all work. It was the switch....Audio out. Some pressing of the remote and the music came out.That is at least solved ... and a vote of confidence that speaks volumes. Funnily, as I decamped a couple of weeks ago to a second system, I pondered if I might not need another T20! Guess in fact you need another DAC also!
Worn the t-shirt! I will check them all tomorrow, thats system 3 ( of 4) sited in my wharehouse C of my humble abode. Down in the former bricks oven and then wine room, now just an amazing crisp n loud rick n reel bedlam, thanks to the products tested in ASR, that lil 3e Audio is a beast! T shirt is blue Orange amplifiers.Worn the t-shirt!
But : Wiim streamer-dac-t20 pre amp-then to Kali Audio lp60ii. All connected with xlr cable, this way l lose a lot of signal, is the T20 fault or a bad XLR cable? Now Wiim streamer-dac - Kali. Enormous signal (!)That is at least solved ... and a vote of confidence that speaks volumes. Funnily, as I decamped a couple of weeks ago to a second system, I pondered if I might not need another T20! Guess in fact you need another DAC also!
