AIYIMA T20 Tube Pre-amplifier Review
Rate this preamplifier:
    Votes: 10 4.0%
    Votes: 40 16.0%
    Votes: 126 50.4%
    Votes: 74 29.6%
This is a review and detailed measurements of the AIYIMA stereo tube based balanced preamplifier. It was sent to me by the company and costs US $180.
This is an unexpected and attractive design! I love the large and stylish volume control which can be managed using the supplied remote control. The volume function is a bit overloaded with it being power button, the input selector, and mute but is manageable. The back really surprised me:
AIYIMA T20 tube balanced preamplifier back panel digital volume control remote review.jpg
Did not expect XLR balanced input and out let alone trigger support! The included external supply is pretty small and nicely sports a ton of safety logos which inspire confidence.
I must say, my bias is that such a products are horror shows when it comes to measurements. Company shows measurements that are too good to be true for the class. Let's see if we can verify them.
AIYIMA T20 Preamp Measurements
I started with the XLR in/out and set the input to 4 volts, and adjusted the volume to get the same voltage out:
I expected a SINAD of 40 to 60 dB but here, we are at 81 dB! Yes, we have more distortion than a solid state design but if one wants that, it would not be a tube product. Using RCA produces similar performance:
In the interest of time, I focused on balanced I/O from here on starting with SNR measurement:
Wow, this is quite good! I don't think I have tested a tube product with such low noise.
Frequency response is also very good for class:
As is crosstalk:
IMD test shows higher noise than state of the art transistor pre-amp but again, for this class it is quite good:
I expected some increase in distortion at low frequencies but it is less than what I thought we would see:
AIYIMA T20 tube balanced preamplifier THD distortion vs frequency measurements.png
The digitally control volume produces perfect channel matching:
Amazing what happens when a company is focused on proper engineering building a tube product. No unnecessary noise and distortion are thrown in there as is the standard for this class of product. Modernization is in play with balanced input/output, remote control, digital volume control/display and trigger automation support. Really, can't ask AIYIMA to do more. They show that using tubes in an amplifier doesn't need to bring with it embarrassment in objective performance.
I am going to recommend the AIYIMA T20 preamplifier. Kudos for the company showing that such a product can be done well, outclassing many solid state products!
Interesting.
maximum gain? output impedance?
We need to see what the role of these tubes really is here..decorum ?.... with these modern AOPs that accompany them ;-)
Nice. Top marks to our Chinese engineering overlords. Thanks for the enlightening review, @amirm .
Thanks, @amirm
Good engineering "for" some tube gear... but still meh performance regardless.
IMHO, another solution would have been not using tubes at all. It reminds me the tremendous amount of efforts some put to have the best R2R designs performing close to good DS ones.
I see that the power supply could still be improved. There are still 60Hz components visible.
With SRPP tube circuit, the profile changes.
As far as I remember, the SRPP tube circuit is not the most convenient solution.
Maybe cathode follower is better.
I'd also be interested in knowing what the output impedance is. Perhaps it isn't flat with frequency and/or volume?
I suspect the gain is a function of the supplied tubes, but I've seen gain published with other tube pre-amps.
eg, looking looking, Schiit Freya+F - 4 (12dB). I also see there that output impedance is 600 ohm balanced.
@amirm , thanks for this, but any chance you can measure output impedance before returning it, or you see no point to do that for a tube preamp?
It should be easy to measure - set AP input to 600 ohm and compare output voltage with high input impedance reading of the output voltage. A mere Ohm’s law.
