AIYIMA T20 – Audiophile-Grade Hi-Fi Tube Preamp in Development
I did a little research helped with AI on the topology of the T20, the exact role of the tubes and their effect on the sound it produce to understand why it brings so much airyness, openness, deepness and 3D sense of space to the soundstage compared to other preamps I own and why the tube choice has so much effect on the sound result.
Why the Aiyima T20 Brings Out the Tube’s Signature So Clearly
The Aiyima T20 is not just a “cheap tube preamp with glowing lamps.” It’s a well-thought-out hybrid: a 12AX7 running at about 180 V, followed by a swappable LME47920 op-amp buffer.T his particular topology has direct consequences on the sound, the soundstage, and especially on how the tube shapes the music.
1. The tube at 180 V: not an amplifier, but a sound sculptor. At this lower voltage, the 12AX7 does not operate in its optimal linear zone:
Low gain,
Reduced headroom,
Higher proportion of harmonic distortion.
The tube is not used as a clean amplifier but as a permanent color generator. Its signature is always audible, even at low levels.
2. What the tube contributes psychoacoustically
Soft clipping acts as a kind of micro-compression: reverberation tails, ambience, and quiet details are pushed forward instead of being masked by harsh transients.
Even harmonics enrich spatial cues our brain uses to locate instruments. This opens up the stage, adds depth, and improves separation between players: the famous holographic effect.
Transient attacks are softened, highs gain a silky extension, and note decays become easier to follow. The result is a presentation that feels more realistic, natural, and immersive.
3. Why the tube’s signature is exaggerated in the T20
In a high-voltage all-tube design, the tube has a wide linear zone and coloration remains subtle unless pushed. In the T20 at 180 V: The tube has almost no neutral zone → coloration is constant. Small differences in construction (plates, geometry, getters) cause big differences in distortion spectrum.
The following op-amp is ultra-linear → it reveals everything without masking.
Result: the choice of tube becomes decisive. The stock Psvane with an airy voicing will create a huge and detailed stage, while a Linlai by example may sound more centered and intimate.
4. The importance of op-amp neutrality
The tube is the artist, the op-amp is the messenger so “flavored” op-amp (Burson, Sparkos, Staccato, etc.) can inject its own harmonics and blur the holography.
A neutral monolithic op-amp (OPA1656, OPA1612, LME49720/LM4562, OPA1642, or dual OPA828) acts like a transparent magnifying glass, faithfully transmitting the tube’s sculpted signal.
Psychoacoustically, the neutrality of the op-amp is the guarantor of the 3D soundstage. The less it interferes, the more the ear and brain can fully enjoy the tube’s euphonious harmonic veil.
5. Why the T20 is actually well designed
The tube runs at a high enough voltage to actually matter (not just glow).
The op-amp provides a stable, low-impedance, noise-free output.
The T20 is real balanced and the circuit is simple and short, with no gimmicks.
For its price point, this is a surprisingly coherent and smart design.
Conclusion
The Aiyima T20 doesn’t use its tube as an amplifier, but as a generator of psychoacoustic harmonics. Details, reverberation, and note decays are highlighted. The soundstage gains holography and depth, depending directly on the tube’s voicing.
The op-amp must stay as neutral as possible to preserve this effect.
In short: with the T20, color comes from the tube — the op-amp should disappear.
^^^ oh, lordy.
:facepalm:
Why?
RCA input=Red Light (at least easy to remember :))
I am glad to find out that using RCA output does NOT make the signal go through extra opamps to convert balanced signal to RCA and vice versa.
On the other hand, in stock form (stock wall wart, Stock LME49720, Psvane 12AX7), T20 so far is doing exactly what I thought it would, shaving off a little bit of top-end detail ("edge" on some recordings) and adding a bit of roundness to vocals. I suspect this tube preamp will do well in systems based on certain class-D amps or "sterile" amps with resulting sound a bit too bright and thin.
*Edit*
I had some Sylvania 7025/12AX7a tubes around, so rolled them in. NOW, T20 is providing sound one would expect from inserting a really nice tube preamp. More harmonics and sparkle, even thicker/richer midrange, while still smoothing some edgy recordings. Psvane 12AX7 is not a bad tube at all actually and is neuralish and clean, just less of that tube sound one is presumably seeking here.
It is the case, using RCA there is a OPA1612 per channel conversion on the input and a the third LME47920 on dip8 socket on the left for balanced to unbalanced to output in RCA. The solution to avoid the two opamps conversation is using Neutrik RCA to XLR connectors if you have already high quality cable and don't want to spend money on a XLR cable there will be no audible difference if you use short cables but you will loose 6db gain
I have good XLR cables and already tried XLR->RCA adapter and ran the T20 XLR output signal to RCA input of Douk A5 amp, and this strategy does not work. Pin 3 likely needs to be disconnected.
Your Douk Audio A5 likely has an RCA input with a "floating" or isolated ground. When the Neutrik adapter connects pin 3 (cold) to ground, it creates an electronic conflict that can cause distortion or cut the sound.
The 3e Audio A5 has a more standard RCA input where this same grounding does not cause a problem. That's why the adapter works for me but not for you. XLR cable is the best solution when possible and avoids all these compatibility issues and provides the best performance.
Finally, I try 24db/octave HPF with Monitor Bronze 50 6g, 62hz-20khz. A20 has 4 markings 60hz 80hz 120hz 200hz, and there are total 40 levels adjustments. I turn 5 clicks clockwise, ~70hz. Theoretically, cut out unusable frequency, minimize distortion. I love this function.
Thanks, Christian Schwarzbeck. T20 & A20 XLR inputs can connect to TRS too.
Al Overview
Amplifier burn-in is a period of continuous use for a new amplifier to allow its elec-tronic components to stabil-ize and reach their optimal operating char-acteristics, often resulting in a change in sound quality.
Al Overview
AI is flat out wrong.
Hi. Im going to use T20 with Lake People Amp G108 with rca output to rca unbalanced input of Amp. Oppinions? Recommendations? I bought 3 opa2604ap's.
Finally Ill use balanced output to amp. Ill use rca on amp to an Hifiman EF400 gold.
What is it not balanced opamp?
Low gain,
Reduced headroom,
Conclusion
Mate - all your AI is doing is regurgitating audiophile mythology that it's found online or from its training set.
That is all utter nonsense.
If the tube is running non-linear as the AI suggests, then all it is doing is throwing a shit ton of distortion all over the music - which does nothing to enhance audio quality.
Al Overview
(doubled text snipped)
