- Joined
- Sep 10, 2020
- Messages
- 213
- Likes
- 729
️ [AIYIMA R&D Feedback Wanted] — New DAC for A07 Max / T1 PRO ️
Hi audio friends
We’re working on a new desktop DAC designed to perfectly match your A07 Max power amp and T1 PRO tube preamp — same size, same look, better sound!
We’re building it with a full aluminum case and color-matched options, to give your setup a clean, unified aesthetic.
Now, we need YOUR opinion on two possible directions
️ Option A: Pure DAC Version
Inputs: USB / COAX / OPTICAL
Outputs: RCA ×1, SUB OUT
(Do you use Sub Out? Let us know!)
Chipset: ES9038Q2M or AKM4493S + XMOS XU-316
Supports: PCM 768kHz / DSD512
Design: NO volume knob — meant to be paired with a power amp or preamp
Extras: Input memory, standby mode, small screen, input indicators
️ Option B: DAC + Headphone Amp Combo
Inputs: USB / COAX / OPTICAL / Bluetooth
(Should we add BT?)
Outputs: RCA ×1, Headphone: 3.5mm + 4.4mm
(Need both? Balanced?)
Chipset: ES9038Q2M or AKM4493S + XMOS XU-208
Supports: PCM 384kHz / DSD256
️ Design: WITH volume knob — standalone DAC/headphone amp
Extras: Volume memory, headphone/speaker switch, input LEDs, etc.
️ We’d love your feedback!
Which version would you actually buy?
Do you use SUB OUT? Bluetooth? Dual headphone jacks?
What do you really want from a desktop DAC?
Your comments will help us build the perfect DAC for real-world Hi-Fi lovers — especially those pairing with the A07 Max & T1 PRO!
Thanks in advance,
— Team AIYIMA
Hi audio friends
Thanks in advance,
— Team AIYIMA
