Aiyima DM100 | Owner's Thread [+ some basic measurements]
Do you find DM100 transparent and a decent source option?
  • YES
    Votes: 1 100.0%
  • Somewhat
    Votes: 0 0.0%
  • NO
    Votes: 0 0.0%
Guddu
I bought DM100 from Amazon about a month back to see if it I could replace my surface pro and shield pro from media playback, audio library and Plex duties. Earlier I tried Pi4 which failed, then started looking to build Pi5 but then thought of trying DM100 with Amazon's 30 day return assurance. I don't think I could build Pi5 as nice as DM100 and now quite happy with it.
Here are some measurements to check some basics:
Source: DM100 playing REW saved test/measurement WAV files, with DMM calibrated output
DM100 ===> USB/Optical/Coax Out ===> Topping E50II ===> TRS Out ===> (TRS/XLR Input) Topping E1x2 OTG ===> USB C ===> Laptop with REW
DM100 Volume: Max, it disables preamp function on DM100
Topping E50II Volume: Max / 0.0 dB
Limitation: Using JAVA EXCL drivers which max out around -105 dB THD/N. ASIO provided better results around -108dB but REW was freezing or crashing with ASIO, so I am sticking to JAVA EXCL.
*** If you think some of these might need a retest with different parameters then please feel feel to let me know, I am happy to learn and improve ***
1 KHz Noice/Distortion:
Test File:
1 KHz Noice/Distortion: DM100 USB Out
1 KHz Noice/Distortion: DM100 OPTICAL Out
1 KHz Noice/Distortion: DM100 COAX Out
Note: Its hitting the limitation of audio interface and should measure beyond -105 dB with a better measuring device.
Frequency Response: DM100 USB Out
Jitter / J-Test
MultiTone
What do you make out of it?
Well the measurements are impressive. I'm reasonably confident I would not hear any artefacts from this device based on your results.
Nice job on the measurements. I cannot find info about the DM100 being able to send multichannel DSD to an AVR through the HDMI either from ripped ISO or DSF tracks. Does anyone know? I know the A6 can but it's the only thing holding up my decision to buy one. Thanks.
Nice job on the measurements. I cannot find info about the DM100 being able to send multichannel DSD to and AVR through the HDMI either from ripped ISO or DSF tracks. Does anyone know? I know the A6 can but it's the only thing holding up my decision to buy one. Thanks.
I am able to play DTS files on VLC with bitstream.
I will try to find a multichannel DSD to test.
Reactions: GPJ
I received a reply back from Ayima ......... "only supports DTS multi-channel audio"
So I guess it's A6 for me, I have far too many DSD ISO's ................
