Almost all externally-powered "chip amps" have those connectors. I have yet to read or hear about about such a "little thing" failing, regardless of the current draw involved -- have you?No way, until that springy power connector is used.
How many amperes should this little thing withstand?![]()
These days if they included that, it would be toutedThere's no mention of PFFB
Saw just two times.Surface-mounted NE5532s will frustrate the op-amp rollers -- and I heartily approve!
There's no mention of PFFB and the FR graph doesn't specify load impedance, so clarification about that would be nice.
So it would seem...These days if they included that, it would be touted
No doubt there are "better" alternatives -- just saying that "little thing" has been proven adequate for over a decade at this point and has become a de facto industry standard which, unlike the "better" screw-on connectors, allows for zero-DIY choice of off-the-shelf power bricks.Saw just two times.
The first was a little amp, so I may suppose it was just a mechanical fail, the second wasn't an amplifier and went quite bad with male connector just melt inside the slot.
I am not saying all these sockets are bad, but at the rated amperage level this amplifier could requires, I'll consider something like the one installed within the Topping B300 a better approach.
Asking a lot from a power amp.Why aren't they offering DSP control noting exciting noting thing new
I think bt20a max is a bit overpriced. For $240, I would want decent DAC included.Fosi BT20A Max is the same for $240 and less features and everyone love that thing
I will agree with that. It's also not a dual chip amp which may not be any particular disadvantage but my own interest is in what Aiyima have done here with the dual TPA3255.I think bt20a max is a bit overpriced. For $240, I would want decent DAC included.
