D
Deleted member 72219
Guest
Sorry, I originally misread you as saying that including HPF would be a big mistake, hence why I questioned you (I must’ve imagined a comma after the initial, “No.”).Most integrated Class D amps with a subwoofer output lack a high-pass filter (HPF). Including one would have significantly disrupted SMSL's dominance in the market with models like the AO200 and AO300.
The Wiim Amp, even with an HPF, doesn’t match the power and performance of SMSL's Infineon chips or Aiyima’s TI-based amps.
Adding an HPF to an integrated amp typically requires a miniDSP, which costs several hundred dollars.
They missed a big opportunity here. A high-pass filter is a game-changer for a 2.1 desk setup compared to the low-pass-only sub out found in amps like the AO300.
-Ed
