AIYIMA A80 Stereo Amplifier & DAC Review
Rate this amplifier and DAC:
    Votes: 8 2.9%
    Votes: 37 13.4%
    Votes: 151 54.5%
    Votes: 81 29.2%
I would buy 48v 10a psu and be done with it, trust me this feeling or curiosity isn't good even though you may not be able to max out power on a 48v 5a psu.
Any extra power isn't bad even if you don't use it, unless the price difference is bothering you.
And its just not about the purchase you are making now (i.e., A70 or any other for that matter), that 10a could be used with your next amplifier if these manufacturers come up with something optimized in their future iterations of these amplifiers that could use 10a even in better way.
This is what I’d do, so I agree. Buy once, cry once.
Ok, good idea, price doesn't bother me that much. I still don't know which amp is better, do i have to test and listen both? Now i have A80, very good sound with Fiio k11 r2r dac+ Elac Debut Reference b6. But this review of A70 which it looks better on mearusements... I can't stop thinking about it :D
You already have the A80. Just enjoy that for now, and if you really want an objective performance improvement, keep saving up for something with Hypex or Purifi inside instead of TPA3255.
Yes i have it, but still i can return it for full money and get cheaper A70 for 40EUR less, and get for that better PSU or better opamps.
Given that, yeah, return it for the A70 with the upgraded power supply. Don't bother messing with the op-amps.
Changing opamps will not change the sound? I heared that SX35B opamps are very good to this amps.
Please see this:
And this:
And this:
Given that you have a DAC you already prefer, I would softly suggest to go with A70. If anything, you will have an amplifier from best of TPA3255 category to keep the urge down. I would also softly suggest to use balanced connection if your DAC has.
I do have both A70 as well as A80 (in fact many more other TPA3255 amps), here are 2 threads I started for owners/users to share their feedback/opinions. Hope you might find some good info:
Anyone using aux as sub output on A80? im hearing quiet buzzing from sub after turning off A80. I have also aiyima D03 which doesnt have such a problem with sub.
Am I doing something wrong because the VU meter doesn't move at all at lower volume levels?
I'm surprised at how hot the Aiyama A80 runs. I thought Class D amps were like 99% efficient? This one gets quite hot (over 40 degrees) even at low volumes.
I came from a Topping PA3s which ran very cool, by comparison.
I've also noticed a very slight audible hiss coming through my speakers with the Aiyama. I don't notice it really, until the amp goes into standby mode and suddenly I'm aware of the _lack_ of the hiss.
I wondered if these issues are normal or did I get a defective unit?
There's no hissing on my device, even when I turn the volume control all the way up. However, I swapped the NE5532P OPC for a very good SX52B. There shouldn't be any noise or hissing via the USB-C (digital) connection. To test, connect it to another PC, such as a laptop.
Yeah, there's definitely a (very small) amount of noise that plays when it's turned on, regardless of whether it's on RCA inputs or USB-C.
It's very high frequency, and very quiet, but it is audible. Swapping back to the Topping PA3s, I get actual dead silence.
Since no other review confirms this error, I suspect that your device might not be OK. Exchange the device. There are now several versions of the A80. Mine is version 2, the old one was only version 1.
Version 1 = old
Version 2 = New
That Op Amp sandwich has a humorous countenance.
I'm sure they have an equally humorous price tag.
Chuckle heads gonna chuckle.
Hi Schreiber, no, the two together cost only about €28 on Ali. And I rated the A80 sound from 7.5 to about 9. Highly recommended.
What's the difference between version 1 and 2?
I bought my unit on Aliexpress, so based on my previous experiences, it's not cost effective to return/exchange things.
I can't say because I don't know. But I can say that there's no background noise on my a80, and I have version 2.There should be no background noise via the USB C as it is controlled digitally.
I asked Google AI Search what the difference is, and it said:
The difference between the Aiyima A80 version 1 and version 2 is version 2 uses the newer ESS ES9038Q2M instead of the ES9038Q2M in version 1.
Classic AI rubbish.
Classic AI rubbish.
Record the noise and upload it to me on YouTube. ... How old is your motherboard? Older than 3-5 years?
