Svend P
This is a site for science, not opinions.I'm not alone in that opinion, and that's a good thing.
That has nothing to do with belief; I can hear the difference. Wow, try it yourself. I seriously doubt that you've ever tested a DAC with a Sparkaos against an ancient NE5532P. You're drawing your conclusions from just one video. I've tested it and I know what I'm talking about, since I listen to the sound every day.Doesn't make it true, though. Lots of people believe in stuff that's probably incorrect.
Ask yourself the following questions:
1) Are you competent in designing electronic circuits?
2) Do you understand how the circuit you are modifying works in detail?
3) Did you simulate, calculate or measure the outcome of changing the components in question?
If your answer to any of these questions is "No", you almost certainly made the circuit work worse than without your alterations.
These device have been designed by very competent engineers with years of training and experience, using detailed calculations and specialized software and often guided by proven reference designs by chip manufacturers with decades of experience. Unless you match that level of knowledge, which chance do you think you've got to improve on such a design by essentially randomly grabbing parts from a bin and shoving them in there?
You think you hear a difference. That's not the same as there being a difference. Read a bit about bias and try to understand why our sense of hearing is unreliable and deceptive.That has nothing to do with belief; I can hear the difference. Wow, try it yourself. I seriously doubt that you've ever tested a DAC with a Sparkaos against an ancient NE5532P. You're drawing your conclusions from just one video. I've tested it and I know what I'm talking about, since I listen to the sound every day.
That's literally impossible and if you read the linked article about bias, you would understand that. Please read more and argue less. There's a huge amount of knowledge on this forum. Use it to your advantage.I'm the only one here who isn't biased.
I'm saying that your impression is biased, which it is because you're a human and not a robot. I'm also saying it's extremely unlikely, not impossible. Please read more carefully.I can clearly say that for me, there's definitely a huge difference. You're just saying that theoretically it can't be...
Logic and science. My arguments are based in science and therefore the opposite of baseless. If you want to refute my point of view, you will need to provide objective evidence.who says it has to be that way? Your answer is completely baseless.
For people who live in warmer countries and have issues with heat, I repasted the amp with great success. I used Honeywell's PTM 7950 phase change thermal pad. Now the case heats up more (which is a sign of better heat transfer). The heatsink of the tpa3255 chip makes contact with the bottom of the case, and the entire cased is used as a passive radiator. Lifting up the amp from its stock feet also improves temps.
www.audiosciencereview.com
I meant![]()
AIYIMA A80 Stereo Amplifier & DAC Review
The sound is there even if I unplug the USB and RCA jacks, so don't think it's actually coming from the computer. (It's plugged into a Macbook Pro M4) I will try and get a recording. That's a good idea.www.audiosciencereview.com
What do you mean ? My unit was bought few months agoI feel it might be unnecessary unless unit is years old
My bad, pls scratch that comment. I read later that you had that issue with it and meant something slightly different but autocorrect making things difficult.What do you mean ? My unit was bought few months ago
Hi, Can you still switch the display off on the new version when the amplifier is playing music? I cant see any "lightbulb" button on the new version of remote control like ther was on the old one.Thx ... I bought the new interface. It costs about €21 on AliExpress. I especially like that the auto standby is disabled. It makes the A80 absolutely perfect with the SX52B. Awesome piece of kit!
Thanks, that's a feature I will miss then. I am not sure I understand what the "turn off standby" feature would be useful for? Can you tell me if it still displays a message on the screen when it has auto switched itself to standby after 5 mins of no signal, like the old version does ?@Sowst Unfortunately, you can't completely turn off the display. You can adjust it in 10% increments from 10% to 100%.
The best thing is that you can turn the car standby off.
