Aiyima A70 [TPA3255 PFFB Stereo] - User Impressions | Owner's Thread
I would personally not worry about sound quality as both are superbly comparable.
Even though I have both in my running stereo setup, I have not tried to compare A70 with v3 mono.
However I have compared both with Topping PA7 for long durations, and all I can say is A70 has nothing less than PA7.
I see A70 as integrated stereo amplifier while v3 mono as power amplifier.
But there are other differences, let me try to put together what I think:
Aiyima A70 vs Fosi v3 mono - Differences
1) Running Temperature
A70 has been running on warmer side even when tested abused. While v3 mono pair have been running on hotter side.
2) On/Off Pop Sound
A70 doesn’t have any pop sound while v3 mono pair has good enough to scare me off for speakers.
3) Integrations w.r.t. auto on/off
Fosi v3 mono is comparatively easier to integrate because it has signal sense to wake up and sleep off, point is that it can work with any cheaper DAC with no trigger out.
Aiyima A70 has triggered in, so works well with AVRs as most has triggered out or with DACs with triggered out as well. Otherwise automating On/Off is a pain, and manual on/off is needed.
4) Sub Out
A70 has sub out while v3 mono doesn’t.
5) Volume Control
A70 has volume control while v3 mono doesn’t. So you have to have volume control on pre-amp or DAC for v3 mono.
6) Placement considerations
Both should be placed in properly vented spot to be on safer side, but A70 requires more height clearance while v3 mono doesn’t.
If you can think of any specific test or comparison then let me know, I am more than happy to try it for you.
Ascend Acoustics Sierra-LX has joined my set up last evening, which is more power hungry than my Elac DBR62 and has more base and lower base extension. Over next few days, I am going to see how all my amplifiers work with new speakers demands.
Not a brief comparison. :) Very useful, thank you! I think I will go with the Aiyima A70. Very little crosstalk, and no heating issues. I may get two units to biamp my speakers.
I have an A70 coming in for another system. Will report here shortly. Meanwhile, Aiyima did a nice take-apart video here:
In terms of design, the position of the main chip and the method of cooling it were poorly resolved.
It was necessary to turn the main board with the power chip upside down so that it was completely on the upper side so that the heatsink was above the rest of the electronics (especially the electrolytic capacitors) and cooling holes should be made on the upper side of the case for better ventilation.
So initial impressions... seems fine and good. I wouldn't call it excessively "hot" at this point. Runs warm, which is fine. A note on the design, they do have little rubber feet on the bottom, and there also additional vent holes on the bottom towards the back. So you get the bottom+heatsink+side venting as the thermal design.
About the connectors, I need some speaker plugs. It's a tight space if you do it with wires. As far as the XLR connectors, that is one area I think they could improve. They don't seem as high quality as the XLR I have seen on some other devices. But that's about it.
The coolest thing is the 48v 5a GAN. This gets a relatively small form factor.
Overall, the form factor is why you would choose this one. If you were matching with an SMSL M500 III, for example.
Уважаемые FM, [<< Если вы еще не видели обзор Амира (что крайне маловероятно): Измерения и обзор Aiyima A70 от Амира >>]
Я надеюсь, что это позволит ограничить другие темы измерений и обзоров их целями, а остальное найдет место здесь, в этой теме.
Я хочу подвести итог:
> что я получаю как покупатель или пользователь стереоусилителя Aiyima A70
> аспекты, не относящиеся к измерениям, которые могут вас заинтересовать
> тестирование функций и возможностей, чтобы увидеть, есть ли какие-либо проблемы и как их обойти, если таковые имеются
> Я также надеюсь, что эта ветка сможет предоставить некоторую информацию о том, «чего ожидать», когда вы собираетесь купить этот усилитель.
*** Надеюсь, другие владельцы Aiyima A70 также смогут поделиться здесь своими отзывами и некоторыми решениями, чтобы помочь другим потенциально заинтересованным/будущим владельцам ***
Упаковка и транспортировка:
Я заказал Aiyima A70 на Amazon 2 июня и получил доставку 6 июня утром.
В отличие от других товаров Aiyima, которые я покупал на Amazon, этот товар был упакован в коробку Amazon, надежно защищающую от пыток при транспортировке.
Содержание, внешний вид и ощущения:
> Содержимое: усилитель A70, блок питания GAN 48 В 5 А и руководство пользователя/документация.
> Усилитель A70 имеет форму кирпича и неметаллическую гладкую отделку, которая предотвращает появление отпечатков пальцев и пыли. Вентиляционные отверстия по бокам и снизу корпуса должны немного помочь с теплопередачей.
> Чип TPA3255 установлен на металлическом радиаторе, который затем прижат к нижней пластине корпуса для передачи тепла чипу усилителя, заставляя корпус работать как радиатор. Это распространено почти на всех подобных чип-усилителях, которые мы видели в последнее время.
Передняя часть блока:
> Регулятор громкости
> Функции:
> Включение питания - одно нажатие кнопки включит устройство, средний КРАСНЫЙ светодиод показывает состояние питания
> Индикатор выбора входного сигнала - после однократного нажатия кнопки включения питания загорается СИНИЙ светодиодный индикатор источника
> Выбор или изменение входа — когда устройство включено, нажмите и щелкните по ручке, чтобы выбрать или переключиться между входами RCA и XLR.
Примечание : запоминает выбор входа после включения/выключения питания.
> Выключение питания — долгое нажатие на ручку регулировки громкости
Примечание : я всегда рассматриваю такую многофункциональную операцию с одной ручкой как потенциальную проблему сбоя, однако она работала каждый раз, когда я тестировал эту операцию, без каких-либо сбоев.
Задняя часть блока:
> Я заметил, что используются компоненты более чем достойного качества, в отличие от маленьких, дешево выглядящих разъемов, которые можно увидеть почти в каждом другом подобном продукте, например, Aiyima A07 Max
> Сбалансированный вход — принимает как XLR, так и TRS-разъемы. Я проверил, как они подходят, и они работают отлично, без каких-либо проблем.
> Однотактные входы - вход RCA
> Один выход на сабвуфер с фильтром нижних частот, для своих нужд я установил минимальную частоту 150 Гц, однако диапазон можно выбирать от 150 до 600 Гц
Примечание : передняя ручка громкости также управляет громкостью выхода сабвуфера, проверено на работоспособность.
> Селектор усиления — позволяет выбрать стандартное усиление или +3 дБ, полезно иметь дополнительное усиление 3 дБ для использования входа RCA
> 12 В Troggered IN - Протестировано с Yamaha AVR, работало отлично каждый раз при тестировании
> Вход постоянного тока - подходит для блока питания 36 - 48 В, я использовал блок питания GAN 40 В 5 А, который поставлялся вместе с устройством
> Клеммы для крепления акустических проводов - явно лучше, чем большинство других подобных усилителей, как и Aiyima A07 Max, однако они расположены довольно близко друг к другу, поэтому использование лопаток может быть здесь проблемой. Лучше всего использовать 4-миллиметровые разъемы типа «банан» для более безопасного и надежного соединения
Блок питания - 48 В 5 А GaN PSU
> Меньше по размеру, чем другие блоки питания 48 В, поставляемые с усилителями Fosi или Topping
> Он похож на другие блоки питания 32/36 В, поставляемые с Aiyima A07/A07 Pro/A07 Max
> Кабель, используемый с блоком питания, имеет сечение 20AWG, что нормально, однако в большинстве других блоков питания на 48 В используются кабели сечением 18 или 16AWG.
Мощность в режиме ожидания - включено или автоматически
> Измерено на 20А умной розетке
> Когда питание включено, но музыка не воспроизводится: примерно 8–10 Вт
Температура корпуса усилителя
> Как отмечено в приведенном выше утверждении, усилитель потребляет не менее 8–10 Вт в режиме ожидания.
> Сидя примерно в 2,5 метрах от колонок, слушаю на громкости 75-80 дБ, что является моей обычной громкостью прослушивания, она никогда не превышала 20 Вт
> При потребляемой мощности 15-20 Вт корпус усилителя немного нагрелся
> Я включил его на 30–35 Вт примерно на 5 минут с некоторыми тяжелыми басами, но корпус все еще был теплым на ощупь, так что беспокоиться не о чем.
> Я не чувствовал, что мне следует измерять температуру, учитывая мои обычные требования к прослушиванию
Мои настройки, подключение и сопряжение устройств:
ПК и nVidia Shield Pro (источник) >>>> Topping E50 >>>> сбалансированный выход XLR >>>> Усилитель Aiyima A70 Sterep >>>> Динамики ELAC DBR62
Субъективные заметки:
Амир предоставил все измерения, которые могут рассказать вам больше, чем что-либо и кто-либо другой, чтобы объективно оценить усилитель.
>> Итак, вы, возможно, захотите проигнорировать эту часть, поскольку она основана исключительно на моей настройке, реакции в комнате и моих предпочтениях.
Я регулярно использую Topping PA7 в этой настройке, поэтому могу сказать, что я довольно хорошо знаком с тем, как прозрачно ведет себя усилитель с большинством моих любимых треков.
Добавление Aiyima A70 вместе с Topping PA7 было забавным, для дальнейшего прослушивания я использовал выход RCA Topping E50 на Topping PA7 и выход XLR на Aiyima 70. Громкость усилителей была откалибрована до 85 дБ с помощью внешнего USB-микрофона, чтобы добиться максимально возможного соответствия без дополнительных инструментов.
В целом, он звучал великолепно, как и PA7 в моей настройке. Не было настоящего слепого теста AB, потому что я переключался между RCA и балансом с пульта E50, но все равно он был достаточно хорош для некоторого сравнения.
Я полностью сомневаюсь, что кто-то сможет заметить разницу, даже если она есть.
Так что никаких сравнений.
Усилитель Aiyima A70 Sterep с Elac DBR62 - настройка звучит потрясающе, никаких нареканий. Просто ФАНТАСТИКА.
Обладая уверенностью и сомнениями, я включил REW, чтобы быстро проверить, насколько отличается частотная характеристика в моей комнате в месте прослушивания, и не удивился, увидев, что она очень близка к идеальной.
Обратите внимание, что эти снимки были сделаны при размещении микрофона на расстоянии около 1 фута от динамика, без каких-либо изменений в расположении микрофона для сравнения.
Целью было посмотреть, есть ли какая-либо разница ТОЛЬКО (эквалайзерная версия из места прослушивания будет совершенно другой).
Примечание : я проделал то же самое с другими усилителями, такими как Fosi ZA3, v3 mono pair, O-Noorus D1/D3 и т. д. При желании вы можете найти их в соответствующих темах.
Субъективно говоря, Aiyima A70 воспроизводит песни так же четко и плавно, как мне нравится в PA7.
Включение/выключение питания Поп-шум/звук:
> Как я слышал за последние несколько недель, Aiyima задержала выпуск партии продукции, чтобы устранить шум, вызванный щелчками, и, похоже, они наконец сделали это.
> Щелкающего шума/звука либо нет, либо он очень слабый, и вы не услышите его, находясь в футе от источника.
> Самое главное, вам не придется беспокоиться о защите динамиков каждый раз при включении/выключении питания.
> Обратите внимание , что это вызывает беспокойство (по крайней мере у меня) и заставляет меня беспокоиться о защите динамиков.
Шипение/статический шум/звук
> Ни одного, мертвая тишина, даже если я положу свои годы рядом с твитером
Некоторые соображения могут быть полезны при планировании:
Подключение акустического кабеля:
> Banana Plug — самый безопасный вариант для этого усилителя, учитывая расстояние между клеммами. Мне бы очень хотелось, чтобы они использовали расстояние между ними, как в A07 Max, который позволяет использовать более толстые кабели и лепестковые разъемы.
Высота усилителя:
> Как вы можете видеть на фотографиях, я предпочитаю размещать свой прибор под телевизором на столе (для достаточной циркуляции воздуха и легкого доступа), и все остальные продукты Aiyima/Topping/Fosi прекрасно размещались благодаря своей небольшой высоте, но для этого прибора требовалось не менее 4 дюймов свободного пространства.
Сохранение статуса включения питания
> Я управляю своими устройствами с помощью умных розеток, поэтому сохранение состояния ВКЛЮЧЕННОГО питания для меня очень важно
> При выключении и последующем включении питания от розетки усилитель вернется в режим ожидания.
> Поэтому, когда я выключаю и включаю умную розетку, Aiyima A70 возвращается в режим ожидания и для включения требуется нажать кнопку регулировки громкости.
> Это делает автоматизацию немного сложной задачей
По мере того, как я буду больше слушать Aiyima A70 в своей обычной системе, я буду сообщать о любых проблемах или наблюдениях в этой теме.
Было бы здорово, если бы и другие владельцы поделились здесь своими наблюдениями.
в чем практический смысл этого крайне субъективного обзора? Вы могли бы с такой же пользой описать цвет и рисунок обоев на стене. Этот сайт — словно остров объективности, несколько лет назад я был рад найти. Но иногда здесь есть пользователи, которые действительно хотят рассказать вам, как звучат разные усилители, но, слава Богу, вы этого не сделали.
I'm also waiting on the arrival of the Aiyima A70 with a 48V/10A power supply. Currently rocking a Fosi Audio ZA3 with Sparks op-amps with a 48V/5A GaN PS and I'm very pleased with the sound. Using Wiim Pro Plus as preamp/streamer/DAC and the quite linear Wharfedale Linton speakers. Have been in contact with Aiyima through Aliexpress and they confirmed fixing the power on pop sound in the new batch. I have also tested the O-Noorus D1, another TPA3255 PFFB small power amp, with the 48V/5A PS. It's OK but the dynamic range, and particularly the bass, is not in ZA3 class. It gets freaking hot, well approx. 50 degrees Celsius to be honest, in both idle and active state.
Hello! Can you tell me what makes the aiyima a70 better/worse than the fosi za3? Thanks)
Could you please test using RCA input and let me know whether you find any audible differences? Many seem to say the sound quality is degraded using RCA. Not sure if that was based on Amir’s original preproduction measurements that they subsequently fixed or what.
Hi. A70 is not load dependent and is very clean playing. Watch Erin's Audio Corner ABX-testing it with March Audio P501 mono-blocks. Enough power to drive my Wharfedale Lintons perfectly and I use the Wiim Ultra as streamer, DAC and preamp. I have tried connecting av Topping D50 III via balanced XLR input to the A70 and it was impossible to hear any difference compared to RCA. My hearing is good, but I don't have golden ears. I returned the Topping. No need for it. I have just complemented with a cheap but good RSL Speedwoofer 10E and set the cross-over at 50 Hz. I'm very pleased with the result.
That’s very useful information. Thanks for posting your impressions.
Thanks for posting this excellent review and summary. Would you be able to test the RCA input on the A70 and see if you notice any audible difference vs. balanced? I’d be interested whether your experience aligns with Pausi’s above.
I just requested a return to Amazon for my Aiyima A70, as the pot developed noise. Bought the unit in July. Have been very pleased with it otherwise using RCA inputs via a SMSL SU-1 DAC. What a shame :(, I really liked it.
I've had my A70 for a week now to drive brand new Revel M105 speakers. The M105s are specified as only 86db sensitive and dip below 4 ohms impedance so I was looking for more than 100 watts per side with no load dependance. I decided the Hypex NC252MP and Purifi were too rich since the TI TPA3255 based A70 has the same tech. The only other TI TPA3255 amp with PFFB, at the time, was the Fosi mono-blocks which would have been about $100 more for stereo with extra clutter I didn't need.
The amp has far more power than it turned out I needed, although it is still one of the cheapest stereo amps, period. With the A70 volume control at max and the preamp WiiM Ultra's volume control between 20-30 out of 100 generates a SPL of 70-80db in my near field setup. 50 on the WiiM results in over 110db SPL. That's with 75% of the amp's potential power untapped!
I think we've reached "peak" amplification. The A70 can satisfy all but the most exotic amplification use cases for $180 in a box 1/10th the size of a receiver or amplifier of the past. The only drawback is the questionable build quality and reliability and for that only time will tell.
I've bought Aiyima A70 on last Black Friday deals on Amazon. I must say there is nothing to complain. I use it with Wiim Ultra and Polk Audio R200 and it works great. Trigger is very fast and responsive. Set produces very nice clean sound, there is no hiss. I have more that enough power in my room. I've set knob to 3/4 on the amp and controlling volume by Wiim Ultra. It's really fine amp and I like everything except how it looks. I was considering matching IOM Ultra amp but I'm not missing anything in the sound so I'm thinking if it's really worth extra $$ mainly for how it looks.
The AIYIMA A70 replaced my Sonos Amp, which, to my surprise, was rated so poorly by Amir.
My setup: Node 2i (set digital pass through on) > the fantastic RME ADI-2 DAC (volume control) > AIYIMA A70 (connected via XLR). Additional i use the trigger output from the Node for the A70 (A70 standby = 0,33W) and a active subwoofer, connected to the A70.
But, contrary to Amir's test, I have no power on plop but a plop on power off. That's the only thing that bothers me.
Just a heads up for anyone using the A70 stereo XLR inputs.
I'm using the A70 as an additional amplifier to bi-amp some floorstanders.
As I'm in the UK the land of pin 2 hot ...I've had to reverse pin 2 and 3 it was out of phase for me.
Using the unbalanced inputs there has been no noise powering up or down, however using the XLR inputs there is a low level click/pop.
This is utilising the 12v trigger.
Otherwise all good.
10A psu.
Agreed, if it weren't for the aesthetics (minor issue) and the form factor (major issue) I'd buy one of these in a flash.
Form factor is a major issue because by crowding so many functions onto the tiny rear panel, speaker connections in particular are problematic. The only real solution is to use banana plugs which are substandard connections in terms of contact area and consistency.
The other, superior solution is for Aiyima to design their product better. Simply by making it slightly squarer, rather than so very long and narrow, they'd free up more real estate on the rear panel and eliminate these issues.
