Yes the fan issue is easily modded, but the one thing I'd want (if compromising on SQ) is moar power, these days that aspect doesn't break the bank.
Since I'm a DC guy, Fosi CA30 is my current value benchmark, hopefully that will test well once it clears Amir's queue.
> Due to the ear's lack of sensitivity to low frequencies you probably won't hear the noise from a 'noisy' amp
I see plenty of members stating that is not necessarily true? My bookshelves only cover from midbass ~200+ Hz
> we probably wouldn't hear the difference in a properly controlled test.
Bottom line, I really would prefer that all my amps can be used for full range for future flexibility. And since they are relatively cheap these days, I see no need risking their becoming the weakest link in the chain.
> Subs often have relatively high distortion
I will strive for as "clean & tight" SQ as possible with mine, but yes maybe not spending much more on that aspect below, say 50-60Hz
Is fast transients performance related to low distortion?
But you're right in that built-in bass management / xovers really DO add a lot of valueA800 which performs a bit better
