AIYIMA A20 Stereo 2.1 Amplifier Review
Rate this amplifier:
    Votes: 11 4.3%
    Votes: 39 15.1%
    Votes: 132 51.2%
    Votes: 76 29.5%
I don’t see the problem that you’re claiming. If you have a powered subwoofer with crossover and everything, why would that matter? With a steep slope from the subwoofer say at 80 hz, you’ll be down 18 to 24 dbs + by the time you get 200 Hz. Have you really heard such poor matching? Obviously, they could run the sub out full range, but practically they did not need to. Thats why they didn’t do it. Would probably be a simple mod if somebody really wanted to.
I could not get the sub and the speakers to integrate properly. I always had a huge hole in the crossover frequency. From what I have read double stacking analog filters like that (200hz at the a20 and 80z at the sub itself) can make the phase do really weird non predictable non linear things. I'm still relatively new to this so I am not saying I was even doing it right... but whatever the WIIM AMP Pro does for integration is great and measuring it there is no hole.
I have been measuring some small speakers with my A20 and compared response with and without the high pass filter. The change in low frequency roll off for small speakers that naturally roll off around 200 Hz is very slight looks to me like the Aiyima A20 high pass is only 6 dB per octave. Given that the speakers are already rolling off below 200 Hz I am not 100% confident in my estimate that the amplifier has a 6 dB/octave filter. Need to investigate more. If it is 6 dB, then that is just a simple capacitor/resistor network getting switched in and out.
The filter is audible and does improve the sound of very small speakers like the Cambridge MinX 22 but to be honest, I think I will want 12 dB/octave or better for my final solution. I am going to try a Dayton Audio DSP-408 I own and use the amp full range. Long story short, I am beginning to question just how useful the Aiyima high pass filter really is. I understand the DSP-408 costs more than the A20 but it does allow for much more complex crossover schemes and adds parametric EQ too.
If I was buying an amplifier today, I would choose the 3e Audio A7 or Fosi V3 mono dual set as both are on sale for Black Friday for around $239. Yes it is a fair bit more than the A20 sale price but these are better amplifiers and for me, the difference between ~$150 and ~$239 is not that much given the higher performance of the 3E and Fosi amps. I had hopes that the A20 would be in the same performance range as these two other models but it is not.
An in-line capacitor would be 6dbs. An RC or LC network would be 12.
I suggest you read the whole thread. I did determine that the high pass is indeed 12 dB/octave and I apologized to Aiyima because my initial posts were wrong. I stand by my comment that the subwoofer output is flawed because it is fixed at 24 dB/octave with no adjustment possible. Stacking that with an active sub 80 Hz filter will give a poor result. The sub output would be better for most users if it had no filter. I also stated that the A20 is a fine sounding basic amplifier with low noise and low distortion when the filters were all bypassed. I based my multiple comments on my ears, my measurements, and my experience as an electrical engineer. I apologized to Aiyima because as an EE, I should have known better than to publish erroneous comments without examining my measurements more thoroughly.
The Wiim AMP Pro does do a better job of integration because it has DSP capability to adjust low and high pass filters and parametric equalizer to improve in room response. It is in a completely different price range but offers value for the extra $$. I own a Wiim Ultra preamp and have experimented with using it with quite a few different amplifiers with good results.
I just read all of the thread and I did see you mention that. But what you can do is use a different slope on the subwoofer to help blend it better. For example, 12 dbs at 80hz. Not a perfect solution, but it would fill in more, you still might have phase issues, possibly making it harder to tune the system. They could easily modify the amp and just let it run full range. It would be interesting to hear their rationale for the design. The funny thing is that this stuff does sound so good, but they’re still budget components. I think some people here when they discussed these components overlook how inexpensive they are. They stopped looking at every side joint and bent lead on the circuit board. ;) Although I’m less crazy than I used to be, I still have a collection of equipment. When they were on sale during the holidays, I picked up the T and A 20s. Hooked up a pair of LS 50s I had laying around as a third system, and it sounds really amazing. All I did with the preamp was put in a pair of Tele smooth plates, and set the amp to full volume. It did not sound as good in the bypass mode. IMO. My current main amps are currently Purifi and Hypex. Still have some tube amps packed away, but this stuff is less hassle.
Maybe I’m confused, are you talking about a $4000 amplifier or $150 amplifier? I think maybe some people expect too much for their money. The product is a great sounding value product. Anybody who thinks differently is in my opinion being very unfair.
Yes it’s a very good sounding amp imo.
I agree that buyers need to recognize that this generation of inexpensive chip amplifiers compare very favorably with venerated amplifiers from several decades ago that were considered budget audiophile pieces and at prices that are orders of magnitude lower. I own Hafler XL280, Adcom GFA-5500, and Apt Holman One amplifiers that are all in excellent condition. The Aiyima A20 does not have the headroom of those Class A/B amps but is not far off the mark unless I am cranking the volume way past normal listening levels.
Less hassle is a big deal at my age as I downsize. I also have a B&K AV6000 in my home theater setup that weighs ~60 lbs and can also function as a space heater. Replacing that with 6 channels of TPA3255 amplifiers is very feasible and something I will probably do in 2026. I will use the A20 for 2 channels and probably DIY a 4 channel amp using some well regarded 3255 boards that were reviewed by Guntar Smits on YouTube.
Long time listener first time caller...
Just wired up an A20 to a set of Wharfedale Diamond 12.0.
Replacing a 22 year old Altec Lansing ADA880 (which went to Valhalla last week ) on my PC.
Nothing complicated, stock motherboard sound chipset, 3.5mm out to RCA in, running as a pure power amp.
@amirm I owe you a beer or a beverage of your choice. ☕
Thank you for the work you do mate, I've been reading ASR for years, both the A20 and speaker purchase were guided by objective measurement which matters.
The A20 is an amazing amp at the price point.
For the audience It cost $254 dollarydoos here in land down under.
Hi all, I'm curious how this doesn't seem to require a heatsink, but the topping mini 300 does. Can their chips be so different that one runs way hotter than the other? Or it's a matter of manufacturer discretion? I have the mini 300 and the chassis does feel warm.
The mini 300, from the review thread
A20 does have a metal heatsink which is attached to chassis bottom as well for heating dissipation.
TPA3251/3255 amps do require some kind of thermal cooling.
PE.
And once again it needs to be said: don't choose an amplifier for its sound character, however slight. Its one job is getting as close to the perfectly neutral "wire with gain" as technically possible, with as little dependency on the actual load and its behaviour as possible.
Sorry, but I just can't figure out (I'm a noob) what the HPF filter is for in an amplifier output dedicated to the sub (sub-out).
The 2 main speakers are connected to the amplifier's speakers output and the active sub is connected to the amp's sub-out (and the subwoofer controls its crossover).
What does a subwoofer do with an audio signal consisting only of mid/high frequencies (amplifier's sub-out with HPF filter)? o_O
Thank you
Thank you
The HPF removes the bass frequencies from your 2 main speakers (amplifier's speaker outputs). You can adjust the HPF to match the crossover point you set using your subwoofer.
So in the end, if 80dB cutoff is not really the true cutoff, how do I adjust the correct filter levels on both the A20 and the subwoofer?
Try setting the LPF on the sub to 80Hz and the HPF on the amp to 80Hz and see what happens. Level match the volumes. Then, if you have too much bass around 80Hz, lower the LPF or raise the HPF. If you don't have enough bass around 80Hz, raise the LPF or lower the HPF. Integration will depend on how capable your main speakers are at 80Hz and what type of slope your sub has on the LPF. There's no one right answer. And 80Hz is just a starting point for the crossover - you may find that 60Hz or 100Hz works better.
For sub or crossover testing, just look for the 20 - 200hz videos on youtube (assuming you can access online content on your device). You'll hear clear volume changes as the frequencies play. You should be able to identify the general nulls and peaks from hearing them alone. If you want to get into EQ you can tweak them but that's not what you're asking about.
For LPF / HPF adjustments, focus on the 80hz to 150hz region. If you can clearly hear the volume dropping off then becoming louder again (or the reverse), that means you have a null or peak and you might want to tweak the LPF / HPF so that you can get a smoothly transitioning sweep as the playback transitions from your sub to your speakers.
Note also that the sub's orientation / placement can affect how the transition sounds like, and for a lot of subs they have a phase switch. For example, you might find that no matter how you tweaked your LPF / HPF there's always a null in the crossover. Changing the phase on the sub can improve the result.
Finally, another key concern you might have that will affect how you adjust the transition, is if the LPF for your sub is set too high (sub roll-off too gradual), you might hear too much human vocals from your sub. This frequently happens in closely mic'ed, talking head videos in studios where bass in vocals is emphasized, and you end up with 'humming' bassy voices which can be irritating. This is where a null in the transition can be preferable.
I wonder if it's worth it to upgrade from my current Aiyima A07 to this A20. I use Monitor Audio Silver 50 7G speakers. Also, I heard some said that WiiM amp is a better upgrade as it delivers more accurate HPF. So there's that too considering between A20 and WiiM, and if the latter, which WiiM version is most suitable for me. I live in a small apartment and mostly listen nearfield with a desktop setup with my computer.
Are you using, or are you considering getting a subwoofer?
How are you feeding the A07 currently?
Which operating system do you use?
Do you connect your sub to the Aiyima A07's aux output right now? Does your PC have multi channel output? Or only stereo output?
Yes.
I have no idea. I'm not a professional pc user. My mainboard is just those generic one bought on the market. I connect my pc to a dac via usb-c, and from dac to amp. Does that have anything to do with whether I should upgrade my amp, and the choice of which amp out of those 2 I mentioned?
