AIYIMA A20 Stereo 2.1 Amplifier Review
Rate this amplifier:
    Votes: 10 4.0%
    Votes: 38 15.1%
    Votes: 130 51.6%
    Votes: 74 29.4%
This is a review and detailed measurements of the AIYIMA A20 stereo class D amplifier with high-pass filter. It was sent to me by the company and is on black Friday sale for US $157 (normally $195).
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced class D review.jpg
The A20 is the most elegant design I have seen from the AIYIMA. Not only is it stylish, it also has quite a bit of weight to it (for its class). The amp has both RCA and XLR balanced inputs which you can easily select with the switch on the right. It took me a bit to figure out that to activate high-pass filter, you push the toggle switch up a notch past "ON." Nice way to save a switch and still get the job done, allowing the design to look balanced.
Back panel shows everything you wanted but perhaps, had not managed to get in this class of amplifier:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced class D back panel power supply tr...jpg
OK, maybe not the giant, 10 amp 48 volt power supply. :) There is trigger input and of course, its high pass filter which you set with that knob. I like that it has detents and is rather stiff so you don't turn it by accident. You can bypass the volume control by pressing that button for a few seconds. In testing, I did not find a performance difference between using that, or setting the volume to max.
AIYIMA A20 Amplifier Measurements
I started with volume set by pass and high pass filter disabled using XLR input:
Distortion is kept quite low so noise sets the SINAD (more or less). At nearly 94 dB, this is excellent performance:
It is awfully close to our blue range despite the diminutive size and cost. You lose a bit of performance as usual if you use RCA:
Here is actual noise performance which again for the class is excellent:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced SNR measurement.png
Despite implementation of PFFB, there is a slight load dependency:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced frequency response high pass filte...png
And that general peaking. High pass works as advertised.
Multitone and 19+20 kHz tests show the typical behavior of rising distortion in upper ranges:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced Multitone distortion measurement.png
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced 19 20 kHz distortion measurement.png
Channel separation is better than average (for all amps):
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced channel separation measurement.png
The beefy power supply turbo charges the amplifier, producing a lot of power in such a small package with 4 ohm impedance:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced Power 4 ohm measurement.png
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced max peak burst Power 4 ohm measure...png
It is able to maintain that close to bottom of hearing range at 40 Hz:
8 Ohm output is of course diminished but still respectable:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced Power 8 ohm measurement.png
As noted, high frequencies are the enemies of this platform:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced Power 4 ohm vs frequency vs distor...png
Amplifier was stable on power on:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced warm up measurement.png
It does however potentially have a power on/off pop:
AIYIMA A20 2.1 Channel Power Amplifier Stereo PFFB balanced power on off noise pop measurement.png
It is amazing how far we have come in this category of amplifier. AIYIMA was one of the earliest adopters producing performance that was hard to imagine at the time. In A20, it has managed to bring more and more refinement as to define a new class here. Yes, there are a few minor misses like flatness of frequency response but generally, you have a very power full amplifier, with low noise and mostly, low distortion. Combine it with good looks and nice functionality such a proper high pass filtering for subwoofer use and you have a winner here.
I am going to recommend the AIYIMA A20 stereo amplifier.
It’s interesting to compare this to the ZA3. Despite the bigger power supply it has slightly less power, and despite PFFB it has worse linearity.
I was considering swapping my ZA3 for one of these just to get the HPF, but it’s a touch underwhelming TBH, especially as it’s significantly more expensive than the ZA3.
Thanks @amirm Excellent review as always. I think you might have the wrong Aiyima marked in the Max Power at 40Hz graph as it looks like the A80 is highlighted?
Oops. Will have to fix later.
Finally, we have an affordable amplifier with an integrated variable main speaker HPF. Took long enough.
Obviously in many situations, subwoofer LPF, Phase switch/knob, and/or physical placement won’t be able to nail proper integration without digital delay/APF on one or the other without sacrifices, but this is a huge step forward from the traditional:
“we are giving you a (completely unnecessarily) low-passed sub out, which your (likely) powered sub already does internally, and full range mains outs…. haha, have fun ensuring full phase alignment between the two across their hugely overlapping passband where now the sub has a “double” LPF crossover slope and thus an extra severe phase rotation which is basically impossible to align to the full range mains” approach we’ve seen from basically every affordable non-DSP “integrated” speaker amplifiers for the last 50 years.
Kudos.
Had these cheap amp + HP filter combos had been out a year or two ago I might not have embarked on my active crossover-preamp project. An affordable crossover with volume control over both outputs seems to be a hole in the market and I think AIYIMA and DOUK are on to something.
The stepped volume control by the NJW1195A chip is surprising in this class of amp but I'm guessing it's cheaper than a precision 4-gang pot.
Being a not-PFFB topology amp, there's nothing to regret at all.
There is PFFB, but not well integrated.
'AIYIMA A20 Balanced Stereo Amplifier with HPF Tuning 2.1 Amp TPA3255 HiFi Class D Desktop Amplifier PFFB with RCA/XLR Input and 12V Trigger for Passive Speakers'
Not terrible, but if the speaker is 8 ohms or thereabouts over 20kHz and if said tweeter has the massive peaks that many metal-dome types do above 25kHz, you're potentially adding another 3dB to their already too-high ringing output up there and noise or vinyl 'stuff' up there may well set it off. Whether the cumulative errors modulate down to audible frequencies actually occur or not I don't know, but rather than it a price point, I'd personally rather have proper hf performance over 20kHz as well as the high-pass filter for those that want or need it.
Indeed, it's readable... But that's what I call a sloppy, even useless, implementation of PFFB....
There is no significant progress compared to the A80 in this respect....
Most people in the market for a $160 USD amplifier are likely using bookshelf speakers that have somewhat poor performance across the board, and are looking to supplement the most glaring subjective flaw with them (lack of real LF output and extension) with a powered subwoofer.
This amplifier’s HF performance is likely NOT the subjectively limiting factor in most of its intended customers systems, and the addition of a real HPF offers huge advantages in much improved subwoofer integration for the average consumer versus the much worse, traditional “full range mains, LPF sub pre-out” arrangement.
Just my 0.02¢
Great device for those that are not using active speakers.
I like the looks.
I agree, this is standard PFFB probably with cheap inductors, similar to Wiim Amp Pro (Ultra supposedly solved that) or Fosi Mono V3.
It seems to fall a fair bit short of the quoted power specs
With the 48v10A power supply, measured performance was ~178W into 4 ohms (at 1% THD)
That's even less than the quoted power for 8 ohms and miles away from the claimed 250w into 4 ohms.
