Aiyima A20 Mono - New Comer
Hi, Stefan.
Why do you say the HPF implementation is poor? Do you find the attenuation curve too gradual?
The attenuation curve ranges from 20 Hz to about 300 Hz. If you set the crossover point near 80 Hz, you lose a lot of bass frequencies. If you set it closer to 300 Hz, the sub does too much (esp. if you have tower speakers with nice mid-bass). Aiyima A20 mono's HPF is a joke. Suppose their stereo version isn't better.
The way they implemented. See my answe above. Not a serious, usable 80Hz HPF.
So any recommendation? I just want a good amp with good HPF why must it be so hard.
Might be easier to find a decent preamp with bass management and then just attach some decently performing power amp behind it (these aren't tested yet by Amir, but there are plenty others that have been). Then you'll get a remote control, too.
Not sure how's that a positive, unless I lack space to place them all (which I don't).
Less clutter, less cabling, fewer connections, fewer chances for ground loops, fewer devices that could pick up noise, better energy efficiency, single point of control, enhanced functionality due to better integration, etc.
It's no DIRAC, but RoomFit has come a long way.
Anyway, you could do a WiiM Ultra if you prefer to retain your current DAC for the analog conversion, and combine that with separate amp(s) too.
As far as I know, wiim ultra also doesn't work with dac, has to get rid of 1 or the other.
Maybe the only way I can do now is miniDSP. Too bad it doesn't have a local seller in my country, so I'll see how I can buy and get it shipped directly from HK
WiiM Ultra (not WiiM Amp Ultra) 100% works with external DACs, it has digital outputs. I have used it that way, combined with the subwoofer output, via both, USB output to separate DAC for the speakers as well as one of the two S/PDIF outputs (optical or coaxial) again, simultaneously with the subwoofer output, and full bass management in all cases.
But also adds single point of failure and less flexibility/agility.
