hrissim
- Joined
- Jan 15, 2024
- Messages
- 5
- Likes
- 6
30-12-2025 update
I replaced the capacitors with NICHICON 63V/1000µF, as I am powering the unit with a 48V/10A power supply.
I also ordered spare ones, just in case: PANASONIC EEU-FS1J102B 63V/1000µF.
Since the amplifier was heating up more than I consider acceptable, I make an active cooling. I drilled six 4 mm holes at the back plate in the top of it . I also drilled a 14 mm hole on the top, directly above the heatsink, and mounted an 18×18×4 mm micro cooling fan, typically used for RC drone FPV systems.
I don’t care about the amplifier’s appearance — it’s meant to last.
