^Ah, I thought it was lower and didn't see they include the better power supply now. I like the integrated power supply in the more square unit.
They all say that. That is the theoretical maximum they could output.
Note: There is now an option for with or without power supply.
You should wait a bit...
Allo will soon release its TPA3255 which is already positioned as the best TPA3255 on the market
It will support unbalanced and balanced inputs with some innovative improvements (air core inductors, Ultra low noise PSU, new OP amps etc)
I've been waiting for the sample
Pre-measurements are impressive !
THD+N 5W , 1Khz 0.00014
THD+N 100W 20-20Khz 0.0097
THD+N 10W 20-20Khz 0.0091
SNR : about 117DB
To be confirmed anyway )
Sabaj A20a???I also discovered a new crazy amp is a great alternative to the TPA325X, it is based on a dual Infineon MA12070 chip
I also discovered a new crazy amp is a great alternative to the. TPA325X it is based on a dual Infineon MA12070 chip and fully balanced; one chip per channel. The stock PSU is a meanwell and has a very low ripple and buffer is equiped with the Opa1678.. I will review it soon and it is really promising
Online documentation is skimpy.
Anyone know about running this as a monoblock - bridged for subwoofer duty?
Will. Let you all know. This amp is really interesting because of its balanced inputs and its great PSU.
Since I own almost all TPA32XX amps + Hypex Ncore and Purifi : I will be able to compare
