I'm new on this forum, so first of all: hi everybody, thank you in advance for your help... and sorry for my poor English!
To better explain my question, I need to start from the beginning.
Last year (during the first covid lockdown, dreaming about the BIG party I'll organize when all this will be finished...) I decided to realize a cheap PA amplifier. On Amazon I took a small module equipped with a TDA7498e (~30$) and a cheap switching power supply 36VDC 10A (for LED strips/stepping motors, ~35$). The results was REALLY a surprise for me (...I'm too old to trust such a small heatsink): that amplifier can output 22 Veff@1KHz to an 8ohm load (60W), both channels driven. And the sound... is not so bad.
A few weeks ago, tidying up my garage, I found a couple of VU meters and a box (originally used for a preamplifier/electronic crossover) and I decided to (try to) rise the bar in terms of power, using a TPA3255 power amplifier (the "classic" PCB, with 2 x 4700uF big capacitors) and a 48VDC 12.5A power supply. Unfortunately:
- the first amplifier module was faulty (short on the power input);
- the second has shown a behaviour that I have considered as a problem: the right channel goes in OLP -and shuts down- too early (at least IMO). Fault active, OTW inactive... reset required (that means: cycle power, NOT reccomended during a party ).
I've checked the TPA3255's datasheet. Since the OC_ADJ resistor value on that pcb is 22K (that means: protection strategy=CB3C, OC threshold=17.0A) and my loudspeakers' impedance is 8ohm, I think that the OLP shoudn't activate at all; so I've assumed the second module as faulty too, and decided to try another kind of module. So, I've ordered an Aiyima A07 in order to disassemble it and use the bare PCB.
Eventually, here are my questions.
1 - Can you confirm that FAULT and CLIP_OTW signals have no visible feedback (LEDs) on this amplifier?
2 - Did anybody check the OC_ADJ resistor on this amplifier's PCB?
3 - On the review you wrote "...the higher voltage power supply does better with 8 ohm load where we become voltage limited", and the max output power you have reached is 61W @ 48VDC. But: what do you mean with "voltage limited"? In other words: (48VDC - Vfet) / 1.414 ... the expected output voltage should be around 32Veff, that means ~130W @ 8ohm. Where am I wrong? And again: what happens over 61W? Did the OLP activate, did the amplifier shut down, did the power supply shut down? And what's next to resume?
Again, thank you for your help. The Aiyima will arrive on Monday, any information will be very useful to me.
Regards
Regards
