I want you to look at the TPA3255 datasheet at figure 8:
This shows you how much power the amplifier can output at specific input voltages with THD+N of 1%.
Now, let's do the math for all the possible candidates, but first let's assume the power supply are 100% efficient(which is impossible, in reality they are 80-90% efficient) meaning that for every watt consumed from the main it produces 1watt DC.
with a 4ohm speaker:
24V 14.5A: 60W/ch, =>60W/24V=2.5A/ch=5A. We can see this power supply is not limited by current and is able to provide 60W/ch
32V 11A: 110W/ch, => 110W/32V=3.43A/ch=6.875A. Again this power supply is not limited by current and is able to provide 110W/ch
36V 9.5A: 135W/ch, => 135W/36A=3.75A/ch=7.5A. Again this power supply is not limited by current and is able to provide 135W/ch
48V 7.5A: 230W/ch, => 230W/48V=4.79A/ch=9.58A. This power supply does not provide the required current to provide 230W/ch.
Now the amplifier is not 100% efficient, it produces heat:
at 100W(50w/ch) it produces 22W of heat, and at 300W (150W/ch) it produces 53W of heat. And I don't think that the small heatsink on the amplifier is able to provide enough cooling on a closed case with no exhaust air or venting. At best it provides enough cooling for 5W.
At 50W(25W/ch) the amplifier has an efficiency of 80%, which means 50W*0.2=10W of heat is produced. This is twice the amount of heat the heatsink is able to dissipate.
So, my final questions to everybody are: are you planning to cook something with the amplifier? Why do you want 300W if the amplifier is not able to handle that amount of power/heat? And how much power do you really need? 10W max per channel is all you need.
Power supplies are most efficient at 50% of the load. This is their sweet spot. So if you are going to consume 20W(in reality) then use a 40W power supply.
In summary, don't bother with "big" power supplies. It is all about clean power not raw power. A clean 24W 7A power supply with less than 10mV ripple and noise will sound better than a 48V 10A noisy power supply.
You can help cleaning the power supply output with a combination of capacitors to clean the noise(small capacitor) and ripple(large capacitor)
This is why amplifier have those bulk capacitors to help cleaning in supply voltage, but we can add small capacitors to help cleaning the noise also at opamp supply pins:
View attachment 223800View attachment 223801
