From the very start, the A04 was all right with this, but the manufacturer, poor fellow, could not cope with the A07! If now A07 doesn't clap on-off, let's clap our hands for solving a hellish problem! ))Mine seems fine, no issues with it turning on/off either via the switch or killing the power.
So does it still clap when on-off or is affect finally defeated?..
Haven't come up with a TPA3255 power amplifier yet to forget about the problems of this lame attenuator? What an exorbitant problem !! ))
AIYIMA A07 has no pop noise problem. Because the A07 has a pop noise prevention control chip.@AIYIMA
Since the A07 has earned a recommendation from Amir, there are quite a lot of folks eager to try your product and future products.
It will be good if the customer feedback is taken for future SKUs.
This is what I have seen across several forums:
1. The pop issue during turn-on turn-off on the A07. Has this issue been resolved in the A08?
2. Providing something like A07 with an in-built power supply (something like MEANWELL 48V 8A) and NO Bluetooth/USB input (adding RCA plus XLR outs will be a nice touch)
3. For HT folks, 3 channel amp in a single chassis
If you can meet the above requirements in your product line-up, these can easily be the best bang-for-buck Class D offerings in the market.
I read something otherwise in a few places.. maybe I mistook the A04 for the A07, my badAIYIMA A07 has no pop noise problem. Because the A07 has a pop noise prevention control chip.
A similar unbranded model, which was the base model for the AIYIMA A07, is on sale, but this model does not have a built-in pop noise prevention circuit.
A07 does not have BT/USB. It only has analog in - RCA and 3.5mm jack. No balanced in, though.
Is there a link that you can provide?wow I just found out I can buy this amplifier in china for about half the price you mentioned.
I sent it back just for the pop noise. I don't want to risk breaking my speakers.
'Pop' noise is something that is not in AIYIMA A04 TPA3251 !!What do you think the 'Pop' noise is exactly? .
The DC offset voltage of the speaker terminal shows a fairly large value. That is causing pop noise.Just to be on the safe side I measured the DC offset of the A08 to see if the 'pop' sound might be related to a spike of some kind. I'm pretty sure I measured this right with the both speakers unplugged and nothing connected into the RCA inputs w/BT off.
Measurements:
Max Mv after turning on: 31Mv
Minimum Mv after turning on: -232Mv (I did measure -416Mv at one point while cycling on and off quickly)
Resting state after turning on: -6.2Mv
Max MV when after turning off: +154.3Mv (Spikes up before draining to 0Mv)
When turning on I can visually see how the voltage drops to -232Mv then works back up to +31Mv then back down again to -6.2Mv where it stays.
When turning off it spikes to +154Mv then drains out in about 15-20 seconds. I'm wondering if the audible thump when turning on is the -232Mv passing through the speakers?
Is that enough voltage to cause damage to a speaker voice coil?
In AIYIMA A07, SP output is stopped by turning on the MUTE operation of TPA3255 for a certain period of time to prevent pop noise when the power is turned on / off. I checked the A08 board, but I can't find an IC chip to do it.
The maximum DC offset voltage standard for the TPA3255 in a stable state after the power is turned on is 60 mV.
This DC offset voltage actually causes a large amount of current to flow through your speakers.
As you understand, the old Pioneer SX 636 is due to the charging current of an electrolytic capacitor with a large SP output, which was common in old amplifiers.
<<additional information.>>
I asked a Japanese user, but it seems that pop noise does not occur even if the power switch is turned on / off or the AC-plug is inserted or removed.
So I think the product you received is out of order.
