AIYIMA A07 TPA3255 Review (Amplifier)
Friends, can you recommend something with functionality like the Aiyima D05, with optics and a remote control, but with sound quality like the Aiyima A07?
This should probably match it
What makes you think the D05 sound is not good enough?
Maybe this
Hallo everyone!
I wand to find a power amplifier with tpa3255 or better for desktop use with soundcard.
The speakers will be sb Acoustics micro.( 84db, 4ohm, they require 25 watts)
I’m using the regular 07 to drive a pair of 6 ohm Polk RTA 12's. The recommended amplification is 10-500 watts. I've used big Crown amps with them, but the 07 sounds much better, and easily gets them as loud and dynamic as I could ever want. I've been using the 48V PS with it and my Fosi V3 and they never get more then warm. They're so inexpensive that if something ever did go wrong it really wouldn't bother me. I'll just buy another or whatever the latest iteration is.
In the end I went with an Hypex dual mono setup. Much more control on base than my Denon x3500h. Since I couldn't really AB test them, the rest is hard to tell. But it gives more headroom for my center and surround speakers. How looking for a nice neutral pre amp and DAC under 500.
For this of us without metal fabrication skills, would drilling a series of holes along the sides of the A07 Help with cooling? I notice the Fosi Za3 pointing out cooling holes as a feature... No need to point out that metal shavings and circuit boards don't mix well.
You could drill multiple holes in top case near entire surface area of the radiator fins. Would help quite a bit.
Recently I've noticed that AIYIMA has a new model out, a tapping amplifier with pffb function, it looks cool! Expect something new.
立体声最大。输出功率:2x300W(@4 0hm)
·立体声扬声器阻抗:4 - 8 欧姆
etc etc...
This is an Enlgish language forum - any chance you can repost after translation? I suspect your browser based translation tool is letting you down.
Where are the detailed technical data for this amplifier?
·Stereo Max. output power: 2x300W (@4 0hm)
·Stereo Speaker impedance: 4 - 8 Ohm
Supply power :DC24-48V , 5A or more
.3.5mm AUX Maximum Output level: 2.3V
·Frequency response: 20 Hz ~ 20KHz(±1dB)for Speaker output
·Frequency response: 20 Hz ~ 20KHz(±0.5dB)for AUX output
·S/N ratio: ≥104 dB(COA/OPT/USB input)
S/N ratio: ≥100 dB(BT/RCA input)
·THD: 0.008%(@1W)(COA/OPT/USB input)
·THD: 0.015%(@1W)(BT/RCA input)
·Input sensitivity: 0dBFS / 0.775V
QCC3031+ES9018K2M+NJW1194+TPA3255DDVR+SA9123L+TPS5430QDDARQ1+LM16030
Audio input : Bluetooth/PC-USB/OPT/COA/RCA
PC-USB : 24Bit 192Khz
Audio output: SPK OUT(connect with passive speaker)+AUX OUT(connect with power amplifier or active speaker)
AUX OUT: connect with power amplifier or active speaker
3.5mm AUX OUT as output connect to next amplifier with volume control
Я не владею английским языком, прошу прощения, если перевод плохой. Прочитал все страницы темы и в шоке. Тема про усилитель, а вы 90% времени тратите на обсуждение блока питания для него. Также необходимо переименовать тему «Электропитание». Из коробки подключил к нему блок питания от ноутбука 20В - 2А, примерно с ключом от машины, и все работает отлично, звук замечательный, ручка поворачивается в положении 8 часов. Подключите его и забудьте. И вы говорите одно и то же 100 раз, у вас у всех либо низкое напряжение, либо малая мощность, либо название не то, либо график кривой, либо цвет не ваш любимый, как будто у каждого есть комната такого размера стадиона и динамики размером с автобус. Всем внезапно понадобились 300 Вт. Нормальные неглушие люди слушают музыку в обычной комнате мощностью не более 7-10 Вт, а в 07 г. требуется мощность с любым блоком питания. Я попробовал сделать погромче — соседи постучали в стену. Лучше бы обсудили качество звука, как его улучшить, по сравнению с усилителями классов А и АВ. Некоторые задумывались над поднятием вопроса о замене действующих усилителей вместо 5532, но их оттеснили вопросы по блокам питания. Тем, кому не хватает спальни, либо сядьте рядом с колонками, либо купите слуховой аппарат. Чтобы наслаждаться музыкой, необходимо качество звука, а не размер, название и цвет блока питания или большая мощность усилителя. Не все, что громко, хорошо. Гудок грузовик громкий, но слушать его неприятно. Единственное, что не нужно паять для конвертации, это операционные усилители. Специально их не паяли, чтобы каждый мог настроить характер звучания на свой вкус. Да, хорошие операционные усилители не стоят 5 долларов (например, Muses02), оригинальные 5532 (Philips) тоже неплохо звучат, но это для удовольствия, вставьте один раз и наслаждайтесь долго. Лучше почитайте, сколько денег вы тратите каждый день на курение и алкоголь. Тоже удовольствие, но вредно для организма. Я не хотел никого обидеть, но вы, как дети, начали по поводу усилителя питания, и все это было схвачено. Давайте наконец обсудим машину, а не бензин, раз уж так тема называется.
Translation by Moderator: (Please use English going forward)
“I don't speak English, I apologize if the translation is bad. I read all the pages of the topic and am shocked. The topic is about an amplifier, and you spend 90% of your time discussing the power supply for it. You also need to rename the topic “Power”. Out of the box I connected a 20V - 2A laptop power supply to it, about the same as a car key, and everything works great, the sound is wonderful, the knob turns to the 8 o'clock position. Plug it in and forget it. And you say the same thing 100 times, you all either have low voltage, or low power, or the name is wrong, or the curve graph, or the color is not your favorite, as if everyone has a room the size of a stadium and speakers the size of bus. Everyone suddenly needed 300 watts. Normal mute people listen to music in an ordinary room with a power of no more than 7-10 W, and in 07 power is required with any power supply. I tried to turn it up - the neighbors knocked on the wall. It would be better to discuss the sound quality, how to improve it, compared to class A and AB amplifiers. Some thought about raising the issue of replacing existing amplifiers instead of 5532, but they were pushed aside by questions about power supplies. For those lacking a bedroom, either sit next to the speakers or buy a hearing aid. To enjoy music, you need sound quality, not the size, name and color of the power supply or the high power of the amplifier. Not everything that is loud is good. The truck horn is loud, but unpleasant to listen to. The only thing that does not need to be soldered for conversion is the operational amplifiers. They were not specially soldered, so that everyone could customize the sound character to their own taste. Yes, good op amps don't cost $5 (like the Muses02), the original 5532 (Philips) sound good too, but it's for fun, plug it in once and enjoy for a long time. Better read how much money you spend every day on smoking and alcohol. Also a pleasure, but harmful to the body. I didn't want to offend anyone, but you, like children, started about the power amplifier, and it was all caught up. Let's finally discuss the car, and not gasoline, since that's what the topic is called.”
Just…. wow :oops:
...and that, my friends, is how you play the "chip amp" game to win -- that's why I own two extra A07s in case the two in my system succumb at some point I'll just swap in the spares!
Just…. wow :oops:
Yeah, it didn't make much more sense in translation. It's hilarious that he recommends op-amp "rolling" -- which has a near-zero effect on SQ -- but rants on about a supposed ASR overemphasis on power supplies, which are critical in certain use cases, e.g. for those of us who don't live in apartment buildings with paper-thin walls and/or grouchy neighbors and are therefore free to occasionally listen at more or less realistic orchestral (or rock & roll) stage volumes.
Different strokes -- and power supply criteria -- for different folks, Karl! :facepalm:
Да, в переводе это не имело большого смысла. Забавно, что он рекомендует "прокачивание" операционных усилителей - что оказывает почти нулевое влияние на SQ - но при этом разглагольствует о предполагаемом чрезмерном акценте ASR на источниках питания, которые имеют решающее значение в определенных случаях использования, например, для тех из нас, кто не живут в многоквартирных домах с тонкими как бумага стенами и/или ворчливыми соседями и поэтому могут время от времени слушать более или менее реалистичную оркестровую (или рок-н-ролльную) сценическую громкость.
Разные ходы — и критерии подачи питания — для разных людей, Карл! :фейспалм:
There is a separate topic for power supplies for this amplifier. In any case, I have not met a single person who had spare ears in the refrigerator when the main ones were damaged by loud noise. Even 30-50 real (not Chinese) watts is very loud even in a large room.
As if you have any idea have how other folks use their equipment? Do you actually believe that anyone posting here pushes their home stereo gear to point of hearing damage -- and are you sure that's is an honest health concern rather than a case of, "My gear choices are correct and everyone else has the wrong priorities?" :facepalm:
