From the frequency response of the load resistance, it can be seen that the amplifier has a significant output impedance. And what is it like at a frequency of 100 Hz?
I think you understand that the output impedance is dictated by the LC output filter. In case of A07 LC output impedance can be seen below and it is same as circuits recommended in TI application notes. This is again no surprise, only that a common user probably not always realizes this fact.
2 plots are shown, with output filter loaded with 4ohm and 8ohm resistors. Without resistors, there is a high LC resonance peak.
Please take into account that the output impedance is inductive up to some 10kHz, it is not a resistor!!
Simulated freq response of the output filter to 4ohm and 8ohm load
From Bruno Putzeys AES paper, comparison of output impedance of class D UcD amplifier with LC filter outside and inside feedback loop:
(please note this is not the same as TPA3255 with PFFB, TPA3255 with PFFB cannot reach the response as shown in blue plot)
