Any of these that ppl are reviewing and suggesting to be a good upgrade in youtube and forums..Which opamps are you talking about?
The TPA3255 chip that does all the heavy lifting in this amp costs USD $2.1 each in quantities of 2000 pieces. How much do you think would be reasonable to spend on the op-amps that supply the signals to it?Any of these that ppl are reviewing and suggesting to be a good upgrade in youtube and forums..
I would probably think in this terms... not nothing major and costly.The TPA3255 chip that does all the heavy lifting in this amp costs USD $2.1 each in quantities of 2000 pieces. How much do you think would be reasonable to spend on the op-amps that supply the signals to it?
No, the gain is defined by the circuit design (the passive components around the opamp), not the opamp itself. That's why rolling opamps is futile.Edit: if indeed opamps alter the gain structure of the signal and give the extra whompf in the highs I would perhaps think of spending a few bucks... is it true that opamps can do it?
Amir's measurements showed that the A07 Pro has a gain of ~29 dB, and its max power into 8 ohm is 59 W. That mean it only requires 0.77 Vrms input to drive it to clipping. What source are you using with the A07 Pro? Does it give you enough volume with the knob turned all the way to max?Is there any a person not well versed in eletronic can do to give a bit more gain to the high knob control?
Cdplayer, is there any room to boost high gain or it is too close from dist9rtion?Amir's measurements showed that the A07 Pro has a gain of ~29 dB, and its max power into 8 ohm is 59 W. That mean it only requires 0.77 Vrms input to drive it to clipping. What source are you using with the A07 Pro? Does it give you enough volume with the knob turned all the way to
It is much easier to help you if you answer the questions.Cdplayer, is there any room to boost high gain or it is too close from dist9rtion?
Oh sorry, yes full volume almost unbearable power ans volume to be honest. I don't use it beyond 10 o' clock most of times.It is much easier to help you if you answer the questions.
Then all is fine, no need to worry.Oh sorry, yes full volume almost unbearable power ans volume to be honest. I don't use it beyond 10 o' clock most of times.
Not worried just asking if theres any available easy fix.Then all is fine, no need to worry.
As I see it there is nothing to fix. If volume at max is too loud to bear, what else to you need?Not worried just asking if theres any available easy fix.
I already said that it is lacking high gain in the knob control and I'm asking here if there's a easy fix just exactly this nothing else. Why do you mind if the volume is at max?As I see it there is nothing to fix. If volume at max is too loud to bear, what else to you need?
What exactly do you mean by this - what's missing?I already said that it is lacking high gain in the knob control
The treble control knob ? If yes: does it work at all? Does the bass knob work?Not high gain, pardon me, gain in the high knob...
