Mark185
- Joined
- Jan 30, 2025
- Messages
- 135
- Likes
- 132
The high pass appears to have a non-linear response that starts out at 6 dB/octave for the first octave below the crossover set point. It then has a 12 dB/octave slope in the second octave below the set point. It has been many years since I studied analog filter design in engineering school. I need to go back and do some research to see if this is normal for a filter to start at one slope and transition to a steeper final slope 2 octaves away from the setpoint.The high-pass filter (HPF) was set at 200 Hz, and it has a 6 dB reduction at the next octave (100 Hz).
Or am I seeing this wrong?
If that is the case, I have been wrong all along and Aiyima is right. There is a filter parameter known as "Q" that affects the shape of the curve in the crossover region. Perhaps that is what we are observing. A Q value of 0.5 would have a more gradual initial rolloff that gets steeper. A Q of 0.7 yields what is considered optimal Butterworth response. Does not mean Q=0.5 is a bad thing. Q=0.5 is associated with optimum phase shift thru the crossover region if I remember correctly.
