Aiyima’s new balanced amplifier- A20
I have no expectations at all from ASR's tests, because these Chinese Hi-Fi manufacturers have long known exactly how to play this game—pushing static specifications to extremely high levels.
It's just like the 4K and 8K TV market: the static specs look fantastic, every parameter seems perfect, every pixel is precisely where it should be, yet motion performance is often blurry—but there's no metric telling you that. And the worst part is, these issues can be measured, but they simply choose not to tell you.
I think this is a conversation we should have more on this forum. If possible in a very mature way, with at core our common passion and willingness to learn.
One wonders why you buy their products then. There are plenty of far more educated contributors than me when it comes to electrical engineering on this site that seem to trust ASR testing. Without wanting to offend you, but I would trust their point of view over your subjective observations on perceived differences between different amplifiers’ output.
Also, I find your comment somewhat offensive via-a-vis Chinese manufacturing. Plenty of European and American companies making absurd claims about their respective products.
I believe there is absolute merit of ASR work, but the possibility to increase current knowledge or help demystify the hobby shall be a learning path for all.
That's exactly why independent measurements such as those from Amir are valuable.
Also there is PKane's software that allows you to compare original music to reproduced music and compare recordings of different DACs.
The de-mystification is usually very simple and also easily verified.
The discrepancy between perceived sound and measurements does not occur when rigorous and controlled blind testing is done (using the ears only).
It only occurs with subjective (sighted) testing methods.
These facts should tell people where to look and that what needs 'de-mystifying' has already been clear for decades (the reason for most discrepancies).
First one needs understanding of electronic circuits... and not just basic electrics but deeper knowledge of components and circuits and their behavior.
Then one needs to understand measurements and what it can and cannot show.
Then one needs to learn how to interpret the measurements.
Next thing would be to find out about audibility levels, not only from books/articles.
Then it would be handy to know about acoustics and finally psycho acoustics.
The average listener has no clue about any of these aspects or a little from some of it yet make the most fantastic claims all based on subjective observations.
Why would people versed in one or more of the above disciplines need to have 'an open mind' to those that make claims and expect to be validated or ask for a technical explanation.
In the very primary definition of HiFi there is no room for "flavors". Fidelity means keeping the output the most similar to the source as you can... Adding "flavors" to the path goes completely against the basis of the concept. Makes no sense talking about such things in this forum. IMHO for sure.
Anyway we can chat about whatever we may think, of course....but from the objective and technical point of view, there is no value in such opinions (like the ass... everyone has one).
- 100 dB 3rd harmonic distortion at 5 W is a step up from their earlier PFFB designs, so a solid performer but nowhere close to what Topping, 3eAudio and Wiim (Vibelink) get out of that chip.
What are the other three achieving with that chip? Can you explain the maths of how you get to that number as I can’t see it from the charts. Are you describing something that would even be audible?
There is about a 100dB difference between the 1kHz stimulus (5W in 4 ohm) between the rd harmonic.
There is even a 117dB difference between 2nd harm and stimulus.
5W (4.5V in 4 ohm) is +13dB in the shown plots so 0dB in the chart is most likely 0dBV = 1V
And indeed that is far from audible but we are speaking of signal fidelity here (far below audible thresholds)
Easy: +12 dB to - 88 dB
The Topping PA5 achieves - 119 dB (0 to -119, it's just a question where the 0 dB mark was set)
Ok, the PA5 uses a TPA3251. Then let's look at the PA7 which has a 3255, it achieves -114 dB
The 3eAudio A7 even gets to -117 dB
In the end, this is all beyond audibility. It is more interesting to look how the low distortion holds up at higher frequencies. The Topping and 3e offerings are also a lot better at 15 kHz THD or 19/20 kHz IMD than run of the mill PFFB, but Aiyima's marketing measurements don't tell us
Yes, they don't tell us the load impedance. If it is 8 Ohms, 4 Ohms will be worse.
Thanks. Indeed, it is easy now I know where to look!
Is there a specific reason we still dont have measurments on ASR?
Aiyima has supplied all of the Youtube "reviewers" (snake oil sellers) with their units, bunch of them with the A20 + T20 combo, even the ones with like 500 subs and yet we still have no tests on ASR?
4 ohm fits as 5W = +13dBV ;)
8 ohm and 5V= +16dBV
Most likely backlog from Amir.
Re-organize cables, connect to Polk ES15. Feel better instruments sound. Feel open stage. Detail voices. Very satisfied.
just got one, i was looking for an amp with hpf, when this was released.
Trying it with 48v/10a supply and i really like it:
Zero noise, no tweeter hiss at all, no pop on or/off, HPF works perfectly without without any perceived extra noise or anything wrong. Volume knobs feels nice, volume bypass works. 12v trigger works, barelly gets warm to the touch.
Volume controlled it with fosi ZH3 dac/pre with XLR.
Very happy with my purchase, ticks all the boxes and it sounds amazing to my ears with 87 db sensitivity Ushers be-718.
