Aiyima’s First Streaming Music Player — First Look!
Does this streamer support connect features for Tidal, Qobuz & Spotify?
And Amazon Music?
The problem with the Android apps on things like TV's is they suck, at least Tidal and Amazon Music do. The connect facility that lets you use your phone provides a far better UI than the Android Google TV OS which I presume this has.
I didn't see anything about ATMOS support or Connect for any music applications. I'm not sure what this offers over something like the NVidia Shield or even Firestick for streaming, both for a lot less. I guess if you don't have a TV display connected, the built in display and mirroring is an advantage and maybe the included storage?
devices like this are one of the only ways to play Apple Music natively (without the usually lossy AirPlay). narrow use case but valuable to those with that consideration.
Looks promising. A couple of things I'd like to see:
1. Add presets. One of my favorite features on my WiiM Pro are the presets on the unit & remote. With the press of one button you are listening to a radio stream. No wading through the menu.
2. A better quality SPDIF output - like AES or I2S. Preferably both.
Can anyone confirm DM100 can play YouTube/Music video stream to TV through its HDMI output?
Does DM100 do this natively (built-in app) or by downloading (from an app store) or is installing YouTube APK required?
Why am I asking...
Years ago, for the home theater system, I purchased a Denon AVR-X6400H which includes HEOS and provides video of its menu via HDMI outputs.
This got me thinking to add the ability to play (music) videos in the 2-ch 'listening' system. In this era of YouTube, I can find concert recordings of bands I never got a chance to see perform (like Led Zepelin, Rush, Pink Floyd, Queen, Kiss, etc., etc.) and even modern artists - to see how they behave(d) in their 'element'.
I solved this in my 2-ch system rack with a series of NAD products over the years (C388, M12, C658) by adding HMD MDC-card modules to those units which provides HDMI in and out connected to an older VISIO TV.
As my audio journey evolved, I wanted to go smaller with same (audio+video) functionality - resulting in my current 'primary' 2-ch system consisting of an old Samsung Note9 on a DeX base, allows playing YouTube (standard and Music) videos with video going to TV (via HDMI) and audio going to DAC (via COAX or Toslink S/PDIF). This is an awesome setup, controlled wirelessly (from listening position) by Bluetooth keyboard/trackpad. It works and sounds perfect and is invisible in the room, since it feeds active speakers that play flat full-range with a pair of open-baffle stereo subs (fast/accurate enough to keep up) - only speakers and wall-mounted TV are visible (as 'lifestyle' as it gets).
Last year, I was looking to create a 'micro' system (~9"-wide) to make better use of a spare set of GE Triton3+ speakers and Ares DAC and imported an Advanced Paris BX-1 (which has gorgeous real VU meters and hi-bias class A-B in a micro form-factor) from France. So this leaves me looking for a 'micro' source with ability to stream YouTube and output audio and video from other sources too (like a micro-factor DVD/Blueray player). The micro form-factor appeals to me - nostalgic for the old micro racks popular in the 90's (example: Sony CMT-series), but modernized - better sound and video capability (like my other 2-ch systems).
Open source android platform (14) and powerful hardware,
EQ profiles and some sort of room correction, bit perfect playback with large screen,
M.2 SSD mount with 4TB support,
Wifi 6 and Ethernet,
and much more……
Price is a bit high but it seems like quite a versatile package.
Missing DAC function otherwise there couldn’t be any complaints other than slightly higher price.
Any sign of the kernel source, or just a blob that won't be supported after a couple of years?
I can’t tell how long term support would look but I read somewhere that they confirmed at least 2 yrs development/support as you might have read as well.
But in general , Android 14 is placed a bit better and should be good enough for a few years to come.
I tried replacing my Pi3 player with Pi5 but it was costing 200$+ in base config and so I dropped the plan. I am inclining to get one when it becomes available with a return policy for safety to see how it performs. I think it can replace my current source (microsoft surface) for good.
I could never get but perfect audio out on Shield Pro, do you know any way to do that.
If you shut off all the Shield's pre-processing and connect with HDMI why aren't you getting bit perfect? It's all digital.
I meant for audio only, like connecting usb to usb DAC.
HDMI definitely gets pass through to TV or directly to AVR.
Now that PEQ and room EQ are added to DM100, I have ordered one from Amazon last evening. Plan is to replace my surface pro which I use to hold and play local media library.
I have tried Pi3 & Pi 4 for the same in past year or so but could never settle with one.
I don't know if it could play video with bit streaming over HDMI but I am going to try.
Looking forward to any guides, info on open source software/tools that could help in using it as media hub.
I was hoping some pointers by any experienced android platform user but looking like I might need to explore this one spending loads of time.
I am expecting Amazon delivery today in few hours and Amazon is showing all units sold out. Don't know if it was limited inventory or all of a sudden people pulled trigger on it.
I got this delivered today, simply stunning......
Literally took 10 Min to up & running my audio library.
Haven’t used yet but it did get room correction and some audio test tools:
I am going to create owner’s thread to post a no. of posts as I use and find useful apps, tools, guides, issues, fixes etc.
