This is amazing. Thanks for sharing. I had the preamp/poweramp pair of the later generation, and it was such a cool little thing.
Good find. HA1370 may be a misprint, since the level diagram says HA1350, and you can very much get a datasheet for that one (it is, unsurprisingly, a 20 W power amplifier). At the very least, if the HA1370 is real, I'd expect them to be closely related.The Wega 205A sibling to the Aiwa A22 contains an integrated tone control and power stage from Hitachi, the HA1370 (or is it HAI370?). I have not yet found its data sheet.
Here is the schematic with headphone output of the WEGA V210:This still doesn't solve our headphone mystery, as the 205A has plain 220 ohm (1 W) series resistors much like I would expect. Unless, of course, @MAB had modified his unit while repairing it and forgotten all about it. It would not be hard to add another 220 ohm 1 W in parallel to the headphone output. Then I would still expect about twice the maximum output voltage into 300 ohms though, and less output than observed into the 32 ohm load.
This was during disassembly to clean the connector contacts, switches, and replace three caps. No resistors were changed! And wires got reharnessed, routed between transformer and heat sink just like original, except I did try to bind them more closely. There is no way to adequately route the wires in a way that avoids the danger zone around the transformer.Probably a wiring issue (magnetic or electrostatic coupling from transformer wiring into some other loop / high-impedance node). I don't really like the spaghetti wiring in there, though at this point it's hard to tell how much it still looks like it did when it left the factory. The banana-shaped PCBs aren't exactly inspiring confidence either, must be an age thing.
OK. I messed up the original measurements.This still doesn't solve our headphone mystery, as the 205A has plain 220 ohm (1 W) series resistors much like I would expect. Unless, of course, @MAB had modified his unit while repairing it and forgotten all about it. It would not be hard to add another 220 ohm 1 W in parallel to the headphone output. Then I would still expect about twice the maximum output voltage into 300 ohms though, and less output than observed into the 32 ohm load.
Only if there is leakage of AC to the faceplate of the amp.... The rack handles give me a nostalgic buzz.
Thanks. At some point I will get all of the model numbers right.The V210 belongs to a different series, though.
Wega V 210 | Hifi-Wiki
www.hifi-wiki.de
I had already provided the link to the service manual from Elektrotanya in post #43Thanks. At some point I will get all of the model numbers right.
I did (finally) find the schematic for the WEGA 205 A, aka AIWA A22:
The headphone resistor is 220Ω, as I saw and consistent with measurements.
The tone/power amp chip is indeed a HA1370, which I was able to confirm is the IC in the AIWA A22.
