Airplay 2 is not lossless, but Airplay 1 is
Now to my problem:
I imported hundreds of CDs in ALAC in apple music and can‘t stream them lossless to my Hifi.
Now to my problem:
Why? Because your hifi streamer does not support ALAC?
If they are not DRM'ed, would you consider converting those files to FLAC assuming your streamer supports that format?
Yes and no:
If you use the tidal app and stream via airplay it‘s lossy.
With Tidal connect it‘s lossless.
Tidal Connect does not stream from your iphone to the Wiim. It „tells“ the Wiim which song to play. And the Wiim connects to tidal.
So Darko is wrong when he say this?
”However, if we pull up a CD-quality stream from Apple Music on, say, an iPhone 13 Mini and send that stream to a WiiM Pro Plus connected to a hi-fi system, the stream will be AAC compressed by Apple Music’s iOS app before dispatch. That’s because the Apple Music app, according to Brother Thomas, operates in AirPlay 2 mode. And so too does the Tidal iOS app.”
Ask Google to explain the difference between "Tidal iOS app vs. Tidal Connect".
See also: "How to use Tidal Connect on iPhone".
I will!
But I am a complete newbie in streaming music, except for bluetooth ;)
If I understood it all correctly, AirPlay is not involved when you stream the music from an iPhopne to, for example, the Wiim via Tidal Connect?
I thought you had to go through AirPlay when streaming from an iOS device via wifi
No. It´s because when I stream from my mac/Apple Music App to my NAD Amp it uses Airplay. No matter which File Format
If I interpret the chart correctly, as Deezer supports Airplay 1, the stream is lossless even though my iPhone and speakers support Airplay 2?
Yes
Just received my Wiim mini today, and I will set it up tomorrow and try it out.
If everything works out fine I will go for a better Wiim in the near future and set the mini up in my daughters room.
