Ai Signal Flow — a web app I built
Juiced
Give it a photo of your hi-fi rack or just describe your gear in text, and it builds an editable signal-flow diagram.
Two free AI engines do the work, both on Google's Gemini free tier: a VLM reads your photo and identifies the gear, and an LLM builds the chain from a text description and acts as a consultant that reasons about your actual setup.
The structured diagram is what lets the AI understand your specific signal path instead of guessing generically.
Fyi,
Does the app store information about users or system types? No:
  • Logging in with Google provides only basic identification details, which are used solely to recognize you upon login and synchronize your drawings across your devices.
  • There is no database mapping 'who holds which system.'
  • The drawings you save are stored in private storage under a key that is a hash of your email—so the path itself contains no identifying details, and only you can read and write your data.
In guest mode (without logging in), nothing is saved on the server side.
Future commercial use? No. The app is free, and I do not sell, share, or trade user information.
If there are any questions—I'd be happy to help :)
What problem is being solved by this tool? Are people not sure how to wire bits of kit together, or can't work out what is connected to what?
Hi @Redacted,
It's not a wiring troubleshooter — it's an AI tool.
You lay your system out as a signal chain (or let it build one from a description or a photo), and an AI audio consultant reads it back.
Where it gets interesting is that it's prompt-based: once your chain is on the canvas, you just ask it things — the way you'd ask a trusted dealer or engineer who's actually stood in front of your rack. For example:
- "What's the weak link here, and why?" — it names the single component or connection most limiting the result, with the engineering reason.
- "Upgrade the DAC or the speakers first?" — prioritised, budget-aware advice ordered by impact per pound spent.
- "Is my phono stage loaded right for this cartridge?" — it checks the impedance/capacitance match and names the value to confirm.
- "Would balanced cables actually help on this run?" — it separates a measurable improvement from an audible one, and flags diminishing returns instead of selling you a tweak.
- "Compare these two systems" — drop in two chains and it tells you which is stronger and why.
It catches the real stuff — gain/impedance mismatches, headroom problems, redundant A/D–D/A conversions, ground loops, domain errors like an analogue source into a digital-only input — and it's built to be honest: it separates established engineering fact from audiophile consensus from subjective preference, and it won't invent specs or prices. Quick question → focused answer; ask for a full review → a structured report.
So the diagram is just the input.
The real point is an AI that reasons about your specific chain, on demand, in plain language.
So, it's for all the totally obvious stuff most ASR folk can do with their eyes closed. :)
I looked at this offering as a possible benefit to drawing connectivity diagram in a home entertainment system.
This "AI Signal Flow" app needs to include all hardware types/assets that would be part of a home entertainment system.
It's a good start!
I initially trialed the app by adding 5 interconnected audio hardware and then realized I needed to add a powerAmp to the mix.
I could not do this addition, lost time/patience and moved on... instead of starting from scratch again. :confused:
My attempt was NOT to have it tell me what is wrong with my system.
I wanted to see if it would afford me "ease of use" for generating an inter-connectivity schematic (wiring diagram), but fell shy of my expectations.
Inclusion of Audio/Video/Wired/Wireless/Analog/Digital/AC/DC functions would also need to be addressed and incorporated for it to serve my needs.
@Juiced, don't be discouraged, forge ahead, next iteration may allow you to come-up with a useful app.:)
It's a good start!
Thanks — genuinely useful feedback, and you've nailed the main goal: the interconnectivity diagram is the whole point.
The "tell me what's wrong" side is optional and off to the edge; the wiring schematic is the core, so you were using it for exactly the right thing.
On the power amp — you don't have to start over. Two ways:
- Add it yourself. Open your system in ️ Stage view and hit "+ Stage" in the canvas toolbar.
Each box is one stage — a piece of gear — so set the new one to your power amp and draw cables to wire it in between the devices it sits between.
Flow view is read-only by design (that's probably why it looked like there was no way to add one); all the editing lives in Stage view.
- Let the AI do it. When you build, there's an "add to existing flow" option — describe just the amp, or snap a photo of it, and it gets appended to the current diagram instead of spawning a new one.
The builder works from either a text description of your system or photos of your gear/rack/cabling, and fills in product shots and port counts automatically.
On assets: a fair amount of your list is already modeled — the diagram distinguishes analog vs digital and wired vs wireless (Bluetooth/IR) across audio, video, control and network gear. AC/DC power distribution is the thinnest part, and I'm expanding it so a full home-entertainment system — mains, amps, the lot — draws end to end.
Give it another run in Stage view, and if a specific device or cable type is missing, tell me which and I'll add it.
Where's the fun in this? I'd rather make my fingers bleed trying to bend Visio to my will and I am very concerned for the welfare of our diagram thread...
I was embarrassed :facepalm: to reveal that I am an old-time user of Visio, when it was not even bought out by Microsoft.
We had worked w/the Visio talented crew long enough to be able pre-release our prototype engineering drawings down to the manufacturing floor to build-to-print, before our internal CAD peeps could ramp-up for full-release versions, cloned from our *.vsd files.
Unfortunately, under Microsoft ownership, they dumbed down Visio :( to a point that even EdrawMax and/or Draw.io offer quicker and more intuitive alternatives, above Visio's 2D.
#Update
The app now is much more easier to use with a better AI agent interaction.
1. Say what you have – the AI draws your system
A list of your gear or photos of your system, and the diagram builds itself: the devices, the cables and photos of the gear.
2. Ask – and get an answer about your system
What's the weak link? What should I upgrade first? The answer is about your models, not rules of thumb.
3. Ask for a change – and the diagram updates
"Replace the Topping E70 with a Chord Qutest", and that's it.
4. Signal Flow – work on the diagram by hand
Tap a device to see its specs (the AI looks them up online). Drag ● to connect, and a wrong connection is flagged with an explanation. Here: a turntable straight into a DAC, with no phono stage.
5. Room Acoustics – the room
Place the speakers and the chair, and see the bass at your seat. The room score suggests the next step, already tested on the model, and you click Apply. You can also measure the room with a microphone.
