vavan
Not quite, something between a21 and a23, but probably closer to a21As far as I know the amp in the older integrated Hint was not the A21 but the lower-end A23
May I know if you have measurements for 1W?I measured Halo A21 in January 2019. It was nothing to call home about. All measurements into 4ohm load. Measuring conditions written in the graphs.
THD vs. frequency
Sure, but at least hinto specs are better than a23There just isn't enough space in the Hint chassis for the A21 configuration. A23 was a cut-down design
Also, any measurements for A23?
Thanks!
Thanks! I do wonder how often the amp would output over 1W if signals from preamp are high passed at 80Hz.I am sorry, I do not have a 1W plot. My time with A21 was quite limited. I suppose it would be fine at 1W, taking into account number of output pairs and Iq.
Perhaps 125 vs 160 watts not a big dealBut the configuration is the same
No, I think that was rather exaggeration on my side, thanks for your clarificationsBut if you want to feel that your Hint has an A21 or something like that, fine with me
I have one of these and can confirm it's quite good. It sounds much better than just using my Soncoz SGD1's digital volume control straight into either my Yamaha MX-1 or my Icepower 1200AS2 based amp. Not really sure why, but the difference is not subtle.I had it here, but did not made any meaningful measurements. Subjectively, it was more noisy (worse S/N). You could hear noise and slight hum if the ear was about 50cm from speakers with some 88dB/W/m sensitivity. My qualified guess is that the integrated is worse than A21.
I also measured Parasound P5 preamp. It was quite good, see attached plots.
Parasound P5 preamp measurements
Intermodulation 13+14kHz test
THD vs. frequency
... I just haven't registered that particular adrenaline rush with the AHB2.
Thanks for posting that, I have not seen this A21+ review yet. The measurements are generally very similar to mine performed on the older A21. However, it seems to me that regarding measurements the A21+, according to Stereophile plots, is a step back. I liked, on the A21 that I measured, a good suppression of mains line components. The A21+ results look worse (to my eyes) and also distortion seems to be higher than that of A21 in my measurements.
What do you think of the Parasound 2125 v2?A21+ is supposed to have a few improved components over the A21 but the Parasounds will probably never measure as good as the Benchmark or good implementations of Class D. However, some people prefer it for its sound signature not as a totally transparent amp which the others would be.
https://www.stereophile.com/content/parasound-halo-21-power-amplifier-measurements
Anyone have measurements of the A21+? Amir's superb review of the AHB2 is great, and I have fond memories of the Benchmark DAC1, so as a company I'm leaning that way.
Only thing that concerns me is the fact that I'm a POS that seems to like noise.
I'm not loving the D90, I think I'd rather have the less accurate Denafrips Ares II.
I'm worried I'll feel the same way about the AHB2.
Can anyone tell me the sonic/audible differences between the two? Different sound signatures etc?
When I saw the Stereophile review of the Ares II the noise floor was below -160 dB on some tests like the jitter spectrum. You might be likening the lack of noise coming from the Denafrips.
