After Replace Speakers - Lack of Bass
ChaoscripT
Hi,
So I replaced my speakers, Edifier R1280DB with Edifier MR4, with the specs they are same+- (The frequency with R1280DB is lower).
I also connect my new DAC SMSL D6 to my docking station with USB and to speakers with TRS cables, in my computer I installed SMSL Drivers and set to 384 bitrate.
Another thing, the old edifier were on the table but now I have some table stand for the new speakers.
I have few questions,
1. It's ok that I set bitrate for 384?
2. Now with the new speakers I don't have bass near, but if I go out from the room I hear the bass.
I've attached photos of my desktop table environment.
Regards.
Could you get them higher and tilted down, so they aren’t covered by the monitor?
bricks or something under the speakers?
Oh, but then they will be very high .. no?
Before I put these stands also my monitors were on the desk, now, the monitors on stand also, and maybe I can return the speakers to the desk (but still behind the monitors), it will give us something?
That is a horrible setup! you're blocking off the bass and midrange, no wonder it sounds off. Without some serious redecoration, I don't see this working properly.
Also, check the knobs on the back that control the bass response.
You can do that, but it's pointless, given that the internal DSP of the speaker is probably working at 48 kHz.
Move the speakers so they are not blocked, even just for a quick check that this is worth doing. You can figure out a more permanent solution after that
Yes I set the knobs to give some bass, but still nothing, I assume because it's blocked, I will check what else I can do.
How I can know how much the internal DSP of the speaker working of?
OK Will do it, will check it.
When sitting at a normal position, you should comfortably see the whole front surface of the speaker and you should be able to see a few inches of space around the speaker. The tweeter should be pointed towards your ears in terms of vertical alignment. For horizontal alignment, the tweeters can point at your ears, or point at a space up to a foot or so behind or in front of you.
How I can be sure that I can lay down these speakers? (horizontal alignment)
It's probably not ideal, sonically, but won't harm the speakers at all.
Ideally, you want the tweeter pointed at your ears, so if you put the speakers on the desk, below the monitor, you'll want to angle them up towards you, something like this:
You can buy some desk stands, that might work, but it looks like you'll need to tilt them back quite significantly, so you may have to come up with a DIY solution.
Is it possible for you to replace the metal pole attached to the platform on the speaker mounts with a longer one ?
I think it's possible, but it will be very high, I don't know if I prefer this way.
View attachment 402503View attachment 402504
I saw this stand for MR4,
(I don't have 3d printer, but maybe it's solution?)
There isn't way maybe I know if it's harm the music/audio when I put it horizontal?
No harm, no risk.
You might find it difficult to align the speakers so they are pointing up towards you and angled appropriately (to make that triangle shape) but you can
just move them around and see what you think.
Get then set up temporarily - propped up on books or whatever you have. When you have them arranged in the best way you can then you can work out how to make that permanent.
Hi,
Out of interest, why?
