olds1959special
I have a complex setup with a multi-output device, four subs and four amps, with the lows going through the crossover of the top subwoofers. Also, the 12" subs on the bottom play the lows from 50Hz down while the upper 10" subs play 50Hz to 90Hz and work as a crossover for the mains (woofers only). I spent hours taking MMM measurements, adjusting EQ and other settings to try to get a flat response in my room. After doing that I did a few more tweaks which subjectively improved the sound, then I measured again. This is what I came up with. I guess I like bass.
