JeremyFife
Take a breath, think about what everyone has said (including the TT naysayers, who know their stuff) and what you've learned.This revelation I've arrived at, thanks to ASR, is what has me leaning toward a Technics SL-1500C. No fuss, direct drive, detachable headshell so I can futz around with cartridges later, and built in phono stage (if I go WiiM Amp to passives rather than WiiM Ultra to actives).
The challenge here is I've got a 300EUR price match discount to take advantage of on a great belt drive TT (Pro-Ject X1 B) that could go balanced from TT to phono (if I wanted it to in the future)...and so if I go that route, it pretty much determines the Ultra path, because I need a phono stage of some sort, even if the investment in a balanced input one comes later.
A balanced output from a TT with a MC cartridge to a phono stage drops the noise floor considerably. I want the cleanest and strongest sound from the TT, in whatever way that manifests...so is a balanced signal from a quality phono stage into the WiiM Ultra/Amp outweighed by an unbalanced signal from a higher quality cartridge directly to the Wiim Ultra/Amp?
I know that depends on the phono stage and the cartridge in question. I also know that the safest answer I am going to get is "you should let your ears determine that"...but if there is NOT a clear answer to the above, I might look at this from a "what do I get for my money right now?" perspective:
The best way to determine this is working from speakers backward - in my restricted listening space "are Revel M16 speakers +200EUR savings equal to or better than Neumann KH 120 II speakers?" If they are, TT option 1 wins. On the other hand, if KH120s are far and away the best choice even considering the 200EUR premium, then that settles it, and I go with TT #2.
- Pro-Ject X1 B > balanced mini XLR output > Pro-Ject S3 B = ~1.1K
- Technics SL1500C = ~1.1K
My view - both options spend too much on the TT - and I like vinyl.
Go back to a cheaper option, Audio Technica with an upgrade path to an AT-VM95ML.
Either option: passive or active speakers works beautifully.
Just because you have budget doesn't mean you have to spend it ... and if you do then the place to spend it is on speakers (or some records!)
(Is it bad that my spell checker now recognises AT-VM95ML
