dominikz
- Joined
- Oct 10, 2020
- Messages
- 973
- Likes
- 3,146
Agree, I'd expect no difference in sound quality - except if something is incorrectly connected.@dominikz I found this thread on Reddit, and it sounds like DA/AD conversions aren't much to stress about from a sound quality perspective.
My advice was only meant to simplify the connection - nothing to do with perceived sound quality.
Digital connection would be just one coaxial cable between the Wiim Ultra to the first speaker, and another coaxial cable between the two speakers.
Analog inputs are fine, of course, but I personally don't see that as simpler. Testing for audible differences between analog and digital inputs might be difficult to do in a meaningful way - you'd need to make sure that the levels are precisely matched (ideally better than 0,1dB) and that you have a means of instant switching between the two inputs without knowing which is playing. Given that there's likely no difference to be heard at all, this might be too much effort to invest.I suppose I could just go with the analog inputs on the speakers and test it out versus SPDIF daisy-chaining and try to hear a difference, right?
Unless of course you are like the very many of us here who simply enjoy the learning process that goes with it.
It is an artefact of poor standardization in audio. Namely, different analogue audio devices may be optimized for different analogue signal level. Having proper gain-staging just means that the output level of the preceding audio device matches the optimal input level of the next audio device it is connected to.what does 'gain-staging' mean? Is that a fluctuation in gains from component to component as signals convert? I am such a dumb-ass rookie.
With a digital connection that is not a concern because the maximum digital signal level is always 0dBFS.
If this is true then it is indeed a good reason to use analog inputs instead!A cautionary note on the spdif interface - some people have trouble with it not waking from sleep, even after Neumann's attempted firmware fix. There's some coverage here including a possible workaround. I don't think it happens with the analog connection.
