- Joined
- Aug 18, 2020
- Messages
- 2,867
- Likes
- 4,721
Others have already answered correctly, but I should respond to your challenge. What I wrote was NOT contradictory, you just didn't read it or understand it properlyyour comment is either somehow contradictory or I don’t get it.
No, I did NOT say that. I said TUBE PREAMPLIFIERS only have a sound when badly designed or broken.You start by basically saying that tubes only have a tube sound when the design is faulty.
Since you are discussing tube preamplifiers to get a "tube sound": you are wasting your time unless you buy something accidentally or deliberately broken.
This is where you misunderstood. I explained that "tube sound" comes principally from tube POWER AMPLIFIERS. Because of their intrinsic high voltage and relatively high impedance, tube power amplifiers normally use large output transformers. These are not linear at all frequencies, all levels and all loads. Coupled with the way tubes behave when no longer in their linear domain, the result is the classic "tube sound".only to later say that tube sound comes from overload behavior which basically also is „overload by design“.
Tube preamplifiers generally don't need transformers and the tubes are operating comfortably in their linear range and so tube preamplifiers don't have a "tube sound".
To reiterate: to get the "tube sound" you either have to use a tube power amplifier, or fake it in hardware or software.
