AES/EBU Switches - multiple inputs to one output
Hello everyone,
I've been looking around to find basic AES/EBU switches that are able to switch between multiple inputs into one output.
My specific use case would be connecting active speakers that only accept a digital AES input to different sources/devices, without having to constantly, manually connect and disconnect the AES cable.
The only ones I found are these:
But those look pretty rough and DIY
And this:
But this is more like an always-on, remotely operated switch.
Are there any other simple but somewhat professional looking options with good build quality?
I don't immediately see a reason for why this wouldn't work:
Yes the second channel would be useless here.
Impedance mismatch?
Are your cable runs particularly lengthy? Otherwise the impedance mismatch shouldn't be an issue.
Total cable run Source -> Switcher -> Speakers should be well under 10 meters..
At what length could problems arise?
There isn't a hard-and-fast limit, but under 10 meters of total cabling will likely be okay. Typically I wouldn't expect the signal loss from the impedance mismatch to be likely to cause an issue unless you're looking at something more like 30+ meters. It should be quite similar to SPDIF, which is often carried over impedance mismatched connectors and/or cabling in domestic setups without issue.
Hello everyone,
And this:
A few years ago I was confronted to the same requirement and found nothing reasonably priced or matching my needs in commercial offers. So I decided to build one myself : https://photos.app.goo.gl/DYpDDbmAqGi3vwWg9
The "bit perfect" silk screen is a bit of a joke ;)
Looks awesome. I wish I had the technical knowledge to build something like that too.
