In our setup there are sound dropouts when power consumers (LED lamps, neon lamps, ...) are switched on the same 230 Volt power circuit.
The problem is caused by the simple "AES-3/RCA-RME-adapter" - which has three problems:
- does not help with high frequency interference problems
- mismatch 110 to 75 ohms
- mismatch of voltage
RME should also give a better alternative in their manuals.
Reduced test setup in another 230 V power circuit:
AES source -> AES-3/RCA-adapter -> RME ADI-2-old
AES source -> AES-3/RCA-adapter -> RME ADI-2 DAC-FS
AES-3 source:
Behringer DEQ2496 or RME HDSP9632: both AES-3 outputs are galvanically isolated (transformer)
AES-3/RCA-adapter:
"AES-3/RCA-RME-adapter" with DMX CABLE 110 OHMS (approx. 1.5 m)
Schematic: e.g.: RME, User's Guide ADI-2 DAC v2.4, page 36.
https://www.rme-audio.de/downloads/adi2dacr_e.pdf
Sources of interference at 230 V:
Small transformer station with a switch that can be operated very quickly.
Results:
RME ADI-2-old (Hardware 1.4):
Audio dropouts are very short but audible
RME ADI-2 DAC FS (Firmware: 27/34 | 34/34):
Audio dropouts are much longer than with RME ADI-2 old. The very fast display "sync/lock" confirms the dropouts.
Workaround (everything has been tested):
Adapter "AES-3 Output to BMC-2 Input" with DMX CABLE 110 OHMS (approx. 1.5 m)
tc_electronic_bmc-2_manual_english.pdf, page 17
https://www.tcelectronic.com/product.html?modelCode=P0CIZ -> "Documentation"
A simple SPDIF toroidal transformer (1:1 with separate, insulated windings) before the ADI-2-DAC-FS | ADI-2-old
If you want to solder the "AES-3 Output to BMC-2 Input" adapter:
If you want to buy a professional adapter and you are living in the EU:
AES-3/RCA-adapter - with galvanically isolated (transformer)
http://www.funk-tonstudiotechnik.de/AES-EBU-Uebertragerkabel-192.pdf
SPDIF RCA connections and TOSLINK cable (of course) have no interference.
AES-3 source:
AES-3/RCA-adapter:
Results:
