Robbo99999
Replying to my own post here just for context because I worked out the EQ filters required to turn the Harman Curve that we use here in ASR into the "proper" Harman Curve of original Harman Research for the Hifiman Susvara headphone. I chose Susvara because didn't we say in this thread it was the most open one & therefore most consistent??Ah, you're not gonna overlay a new curve over the top like you mentioned in your review? Instead you're gonna be listening to the headphones and deciding if you want to boost 3-8kHz by a certain amount each time & you may rest at a different boost level each time perhaps, and praps even zero boost there for some headphones? I suppose that works because the level of required boost there is unknown, so it makes sense to judge that area subjectively.
I suppose it doesn't change the fact there's been a lot of love for the Harman Curve we currently use, so boosting that 3-8kHz could make some headphones overly bright I reckon. Given that danger I actually think it would make sense to also experiment with reducing 1.3-3kHz because that area is showing a consistent reduction in the study too, and that would be synergistic with increasing 3-8kHz because decreasing 1.3-3kHz will make the headphone a bit less bright & therefore make the 3-8kHz boost more palatable on overall tonality - so I reckon it's important to decrease the 1.3-3kHz area too, and maybe even bake that specific change into the curve because it seems common on all of them. I think I'd bake in the 1.3-3kHz change and keep the 3-8kHz area subjectively flexible, I think I'll try that sometime on my own headphones.
Basically it's two filters to convert your current Harman EQ into one that simulates it having been measured on the original equipment used in the Harman Research:
- Peak Filter: 2249Hz, -1.8dB, Q1.492
- Peak Filter: 6462Hz, +2.6dB, Q1.118
My understanding is that this conversion will be most applicable to very open headphones like the HD800 and of course the Susvara on which this is based. @Mad_Economist (or others) please correct me if I've made a wrong assumption.
I haven't tried this conversion EQ on my own Harman EQ's I use for my headphones, but I'll try it when I'm less tired. You can basically just slap those two Peak Filters onto an Oratory EQ for instance.
EDIT 18th October: slapped those two filters on a standard Oratory EQ for the HD800 - sounds good, ended up listening at quite a lower volume than usual on my amp setting, might be related to the EQ change.
