Emiyanez
Hi,
I recently bought a pair of ELAC UFR52 on sale after a demo (which I really liked), but I am having a hard time properly placing them in my room. Unfortunately, I am quite limited in terms of positioning and can only separate them a maximum of 15cm from the front wall. This is causing a severe cancellation (SBIR) right at 200Hz, making the speakers sound a bit "thin".
A fairly wide PEQ boost (Q=1, +4dB) partially solves the issue both in terms of measurements and subjective perception. However, since the crossover point between the woofers and the concentric midrange driver is at 220Hz, I am worried this boost might push the 4" midrange driver past its linear excursion limits at the very bottom of its range, potentially increasing intermodulation distortion.
By measuring the speakers at different distances, I confirmed the dip is pure SBIR from the wall behind them; pulling them out past 0.6 meters completely solves the issue, but unfortunately, that is not an option in my room.
I came across the GIK Acoustics 244 bass traps with FlexRange technology, and I am wondering if installing them on the wall right behind the speakers would successfully mitigate this reflection. Looking at their charts, the 90Hz option seems to be a reasonable candidate since it targets the problematic frequency area while leaving the lowest sub-bass untouched.
Would this actually work in practice given the tight clearance? Also, would a standard 120x60cm panel behind each speaker be enough to catch the reflection, or would I need to cover a much larger surface area to see a real improvement at 200Hz?
Thanks a lot in advance for your help!
