There are subwoofers with different types of outputs. I just took this as an example:
"There are two sets of output connectors on the STA-400D. One set (labeled Line Out) is unfiltered and carries the same signal as found on the input connectors. The set labeled High Pass Out has a high pass filter applied which has a corner frequency of 80Hz and a slope of -12 dB per per octave."
SV Sound SB12-NSD Manual Online: Power Led. The power LED will be green when the subwoofer is on and ready to receive (or is receiving) an audio signal. When the Power Mode switch is On, the LED will constantly be green. When the Power Mode switch is on Auto, the LED will be off when...
www.manualslib.com
This is what the outputs look like:
The SVS SB12-NSD is an affordable 400watt sealed powered subwoofer with a 12” aluminum cone driver in a tiny sealed cabinet to produce satisfying and exceptionally well rounded bass. Small but potent.
www.audioholics.com
So you have to investigate that regarding the subwoofer you are interested in, if you now want that function.
You can also get a DSP and split the signal (LP-HP filter) before the subwoofer amp and the amp that powers your speakers. Or via an active crossover if you don't want to tinker with crossovers in various DSP-related computer programs.
Edit:
With all that said. Consider what I wrote in #26. It probably mostly depends on how I would do it, how I listen to music in the bedroom in and of itself. For me, it's mostly listening at a relatively low volume. I'd rather spend more money then on HiFi in the living room/listening room, but that's me. Not sure you see it that way.
