Advice on system upgrade ( or downgrade ? ). Dali vs KEF
Soulone
Hi,
I currently have a pair of Dali Oberon 7 speakers in a room approximately 28 sqm (4m x 7m), with the speakers placed along the longer side. Previously, I owned a pair of Phonar Veritas M3 bookshelf speakers.
I also have a subwoofer (XTZ 12.17 Edge) dedicated solely to movies.
While I’m generally satisfied with the sound, I can’t help but wonder if I enjoyed the music a bit more with the Phonar bookshelf speakers. These thoughts are purely subjective, of course.
I chose the Oberon 7 over the 5 because I felt the bass on the Oberon 5 was too weak when I auditioned them in-store (although the room there was significantly larger).
Now, I find myself considering an upgrade—though I don't necessarily feel the need to, as the Dali speakers are only 5 years old.
I've been contemplating two options:
  1. KEF R3 Meta – Returning to bookshelf speakers, since towers might not be necessary for my room size. I sit about 3.5 meters away from the speakers.
  2. KEF Q7 Meta
Both stereo and movies running with Dirac eq. Also, due to the room specs, speakers need to be placed quite close to the wall....
Thoughts ? And again, is not that I dislike the Dalis, just wondering if the change would make any sense...
Thanks!
The Oberon 7's specs say it's a 2-way (not 2.5-way) with two stacked 7" woofers, is that actually correct? If so, its vertical directivity would stink, even with the relatively low XO at 2.3 kHz. The horizontal dispersion matching between the woofers and tweeter wouldn't be super great either but probably still decent enough as XO remains decently low for that (think Elac DBR-62 or thereabouts). I'm not exactly impressed.
That's a fair distance to be honest. You should be very concerned with even dispersion, and it doesn't need to be wide either, perhaps quite the contrary.
The Q7 Meta looks like it would be a good start. It's reasonably big, and at 440 Hz the crossover to the two 6.5" woofers is going to be a lot less of an issue than for the Dali. That being said, the R3 Meta is no slouch, has smooth ER and sound power indicating good performance in diffuse field, would lend itself well to placement near the wall with its shelved bass and I would expect better build and crosover parts quality. It should still beat the 2-way Phonar any day of the week.
That's not actually a problem since you have room EQ. If anything, it would improve bass level handling.
How far away are you sitting from the wall on the other side?
Hi All: I've been running a mixing board for live musicians since the 90s, but am just now learning about the Consumer AV Audio world again, since my TV broke, and I bought a Bravia 3 rather than spend another 1000 for OLEd. Trying a soundbar or small under TV Soundbar was lame.
I have a difficult setup because my TV and Speakers need to be up 8 feet high, given my neck injuries. (Photo) Currently, I'm using KEF Q6 Center, 4Ohm speaker 86 db Sen, KEF Concertos
with 4 ohm 85 db sensitivity, and vintage KEF Q15.2 8 Ohm and 91 Sesitivity, all on that front wall, because it produces a good "mix or soundstage. " I am using the Vintage KEF for L/R Surround because of the Sensitivity and 'highs" they reproduce complement the more Bassy Concertos and widen my soundstage. Nonetheless, I am planning on substituting KEF Q35O or perhaps some dipole speakers up there, or maybe another set of KEF Concertos, that I bring down to Center Speaker level, because my challenge is bringing the soundstage down. Any suggestions?
I'm told get that Denon 3800H because it has independent Gain and EQ for each channel. Denon suggested all 4 ohm speakers with it, but then I might well need an External Amp to power all my 4 ohm speakers. Audiophiles inform me that a 7 channel External Amp (Outlaw, Osd, or Emotiva) for all these front speakers would be great, but thought I'd still need to reduce the Volume on the remainig 4 8 Ohm speakers that I was going to position in the more standard install places. and power them from the Receiver. What are your thoughts?
The Only Other Receiver close is the Onkyo RZ 70, but I've read lots of complaint about Onkyo Switching and that it does not play well with 4 Ohm Speakers.
i'm also told a" Very Musical Sub" as opposed to just a (dull thumper) is the svs Pro 1000 2000 Pro 2000, and that it has a huge effect. Any other suggestions?
The idea of wiring in a 2d Center was also Suggested, butce I wanted more advi
Thank you for your anticipated Responses,
